Feature Requests
Some minor "category" feature requests
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
Hi there!
This weekend I used different categories for my inputs for the first time and came across some "issues":
1. Please also colorize the cog wheel on the audio inputs if they are on different layers
2. Make it possible to name the categories
3. Make it possible to show 2 or 3 categories at the same time (just like the way it is with the instant replay and audio mixer right now)
4. Put the category buttons on from the side to the top (I think you already did that with Vmix 17)
5. I would like to order my tabs for example as "live inputs", "overlays", "video clip" or something like that. If you could it would be great to disable live switching on a specific category or make it possible that the "cut" from the "overlays" tab would only put a overlay on the program out and not cut to the overlay graphics (happenend to me this weekend)
The manageability would improve a lot by that.
Regards, Patrick
Joined: 8/3/2015(UTC) Posts: 324 Location: Chicago, IL
I noticed on the February show you will be able to name the tabs. So there are a couple of your requests ready to go as soon as vMix17 is released. Your other ideas sound good as well.
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Patrick, I believe that in vMix lingo "tabs" are called "categories". I like your suggestions, to some extent discussed earlier in Tick boxes for categories. Missed the tab naming in the Feb show, but it seems that at least some improvement is on the way :)
I have changed the thread title, thx Richard
Feature Requests
