Hardware Compatibility
vmix on server 2008 r2 64 bit but no sound card
Joined: 4/11/2015(UTC) Posts: 64   Location: Home Thanks: 7 times Was thanked: 3 time(s) in 3 post(s)
ok, now challenge I'm stuck on..
Right now, I use a laptop to mix video files to run a 24 hour 7 day stream through rmtp to my server..
A much easier and more efficient way would be to run vmix on the server.. Which it runs.. BUT.. the server has no physical soundcard, so I get no sound output.. I've tried several virtual soundcard drivers, didn't work for me at all, no difference in vmix..
The thing I'm confused on is I get sound fine through remote desktop and using vidblaster, vlc, and almost every other app.. Is there anyway and if so, are there any step by step directions to get around this limitation in vmix? all I need to do is mix files (files list) with overlay logo and the ability to manually switch to other file sources when needed..
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
DanteWe use this on all of our systems. We run WDM the ASIO setting gave use problems but we have not tried them in a while. Steve
