#1 Posted : Sunday, February 28, 2016 9:06:54 AM(UTC)
Seems one has to be careful when using the merge transition using virtual sets.(notice the 'screen' movement when using merge transition )
using fade ( or cut) I have another issue , it resizes the output during transition (2nd part of attached clip, not only when using VS's)
vMix 16.115
feedback please
File Attachment(s):
mergetest - 27 februari 2016 - 01-52-42 pm.mpg (2,830kb) downloaded 30 time(s).
#2 Posted : Sunday, February 28, 2016 10:26:44 AM(UTC)
@ doggy
It would appear the "Merge" transition is behaving as designed...
The effect is meant to be used as a transition zoom to or from a 'fullscreen' shot of one of your 'Inputs' in a 'Multiview' shot, which in your case, should be to the video playback monitor of your Virtual Set, not another Virtual Set or 'MultiView'.
The 'Resizing' issue might have something to do with your settings and how vMix sees your source inputs, so I would look at that first.
#3 Posted : Sunday, February 28, 2016 12:40:53 PM(UTC)
Thank you Ice
fade <> merge = be aware of the difference ;-)
resizing issue = pay attention to the aspect ratios en test/adjust accordingly
Bandit62
#4 Posted : Sunday, February 28, 2016 6:59:26 PM(UTC)
Rank: Guest
Groups: Guests
What I do not like about Merge is the dissolve ....it looks a bit tacky, so what I do, I quicken the the speed, and on most projects, it looks ok.....I even use a straight cut.....
I used it a lot at a presentation where the presenter used Powerpoint in their presentations...Did a screen capture, and use multi input to do a PNP, so I could cut from the speaker to the Powerpoint, and then to the PNP, where I made the speaker small, and the Powerpoint large enough to read from a distance....I used a projector for the output screen, so I had a pretty large output....Can not remember the speed settings, but I think I used 250.....it worked great for me...So, you should try a speed change....
