Duoal output: multi/single cam
I have 3 inputs: multicam program and 2 Aux camera for replays/single cam stream. I need 2 streams: multicam/replays/graphics and single cam(AUX1)/graphics I set single cam stream as main view and put muticam pgm on 1st layer, graphics on 2/3 layer. External1 output is for multicam stream set with all layers visible (single cam is under multicam layer). External2 output is for single cam stream without 1st layer (multicam) visible but with graphics.
My question how to integrate replays that it would be available only for muticam stream? Is it possible somehow?
If it's not possible I could show replays for one camera stream, but how can I come back from replays that ext1 would be multicam and ext2 would be aux1? I tried add shortcut that when I use stinger for leaving replay to single cam it would set my multicam view for 1st layer, bet it does'n work nice because my stinger is 25 fps and cut point is 20th frame and if I set fade or cut it doesnt change in right frame. Is it possible to set shortcut that it change camera 20 frames after hiting cut shortcut?
p.s. hope somene will understand what I mean :)))
@ Lzrd
I'm not exactly clear on your requirements or your set-up... Can you somehow provide a video or diagram to better illustrate what it is you are trying to accomplish?
