Sudden Streaming Error - "Streaming has stopped unexpectedly"
Hello ~ Anyone have any clues about this? I have not changed my environment that I am aware of. vMix works perfectly every time. However, the last time I streamed, it didn't work. I get "Streaming has stopped unexpectedly." I followed the instructions listed on the website: I downloaded and reinstalled AFMLE. I downloaded and reinstalled vMix. I looked at the Log file and the error was : FMLE Exited -- Code:[quote][quote][i]"Flash Media Live Encoder has experienced an unrecoverable exception. The details here may help to locate the problem. If the module listed is a third party driver, try updating or using a different driver. For reproducible problems within Flash Media Live Encoder itself, send this file to support@adobe.com with a description of what you were doing when the exception occurred.
Crash at: 2016-02-19 18:27:31
C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe v(3.2.0.9932) experienced the exception
0xc0000005 EXCEPTION_ACCESS_VIOLATION
The instruction at 0x
in module : C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe v(3.2.0.9932) at address 0x00534134
function : [/i][/quote][/quote]
To no avail. I am running windows 7 Lenovo laptop Service Pack 1. (Intel 2.40 GHz) / 20Gig RAM / 64 gig OS 2 HDPro C920 webcams 1 Yeti Stereo Mic
Quote:Flash Media Live Encoder has experienced an unrecoverable exception. The details here may help to locate the problem. If the module listed is a third party driver, try updating or using a different driver. For reproducible problems within Flash Media Live Encoder itself, send this file to support@adobe.com with a description of what you were doing when the exception occurred.
Crash at: 2016-02-19 18:27:31 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe v(3.2.0.9932) experienced the exception 0xc0000005 EXCEPTION_ACCESS_VIOLATION The instruction at 0x in module : C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe v(3.2.0.9932) at address 0x00534134 function : file : EAX = 0x02662000 EBX = 0x02948aa8 ECX = 0x046d0072 EDX = 0x046d0000 ESI = 0x0018ecac EDI = 0x00000000 EBP = 0x046deac4 ESP = 0x046deabc EIP = 0x00534134 FLG = 0x00010206 CS = 0x0023 DS = 0x002b SS = 0x002b ES = 0x002b FS = 0x0053 GS = 0x002b0x00534134 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x02660000 0x00000000 0x046decfc 0x00000000) 0x0041d430 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x02660000 0x00000000 0x046decfc 0x00000000) 0x0041d241 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x02660000 0x00000000 0x046decfc 0x00000000) 0x0041d093 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x02660000 0x00000000 0x29baae96 0x00000000) 0x00428187 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x29baaee2 0x00000000 0x0018f758 0x00000000) 0x00427ce7 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x004289a0 0x00000000 0x0295e188 0x00000000) 0x0043b7f4 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x29babcae 0x00000000 0x0018ecac 0x00000000) 0x00438456 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x00000000 0x00000000 0x0018ecac 0x00000000) 0x00431c69 C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x00000000 0x00000000 0x02948aa8 0x00000000) 0x004aafbd C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x0018ecac 0x00000000 0x29babc3e 0x00000000) 0x0053a11f C:\Program Files (x86)\adobe\Flash Media Live Encoder 3.2\FMLECmd.exe (0x00000000 0x00000000 0x7515338a 0x00000000) 0x0053a1c4 C:\Program Files (x86)\adobe\F
Any clues, much appreciated. Thanks!!
I don't know if this is still an issue for you, but I had the exact same error using FMLECmd.exe and the fix was to delete C:\ProgramData\Adobe\Flash Media Live Encoder 3.2\fmesessions.dat
Once that's deleted, when you run FMLECmd.exe again it creates a new .dat file and works again. Apparently if that file gets too full it keeps FMLECmd from running.
You would think uninstalling and reinstalling FMLE would take care of that, but it does not.
Hope this helps.
1 user thanked mattman for this useful post.
