mikekay
#1 Posted : Sunday, February 7, 2016 5:41:10 PM(UTC)
mikekay
In a computer with multiple outputs, how about being able to select which one is the main output - or which combination of outputs can be used. Right now I have an AMD R9 200 with two DVI outputs, and a Display port output with a Club 3D display port hub. I want to be able to tell vMix which output or combination of outputs to use. I want to use the two DVI outputs as dual monitors to make the vMix interface larger and easier to use with larger preview windows and no scrolling.
