I am making a lemur project for v mix
Groups: Joined: 1/17/2016(UTC) Posts: 142 Location: Nj
It will have multiple iPads controlling different functions ,one for switching one for audio and one for replays I just started it and so far so good ,I am posting pics Digitalson attached the following image(s):  image.png (213kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
Audio Digitalson attached the following image(s):  image.png (111kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
New version more room for Extra kc,s like custom commands Digitalson attached the following image(s):  image.png (181kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
Audio page Digitalson attached the following image(s):  image.png (229kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
looks great..we are waiting for a demo.. thanks
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
Like your control surface.....keep the good work up....a bit colourful, but nice....maybe a 3D look on the buttons, and less so colourful....more Black and Greys...to keep a more traditional appearance, other than that, it looks great, cant wait to see it posted....I really like the idea of the "T" bar....
Great job.
Well right now I am testing the commands cause they are not bidirectional,so I can't have midi feedback for faders and routings and inputs,,,,my orig idea was to make multiple iPads for different functions ,like one for switching and one for replay and audio,cause lemur can share midi in's via loop midi,so a replay guy can set and cue replays thru the iPad only,but this one will have all the pages......and yes I can change colors to grey for off and green for on,,,and I tried to make different buttons but it wasn't happening ,,,,I just make a revision tonight ...I'm stuck on how to do the overlays ,,,,any suggestions would be helpful....ill show u what I came up with Digitalson attached the following image(s):  image.png (206kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
There is no way just to select a input with out putting it in preview to turn on overlays
Rank: Guest
I see you are mentioning iPads, I hope you are making this for Windows and Android tablets as well, since vMix is a Windows program......
Well yes it can be used for android,and I have seen people use android with Windows touch screens but the program is called lemur by line google it ,that's where the file will be when done,,,but still need to figure out the overlays......need suggestions...thanks
