kjones9999
#1 Posted : 9 years ago
kjones9999
AFter several months of solid behavior, today I received the above error on vmix16 x64. It suggested I reinstall, which i did. At the next restart, i received the error again. Vmix will not start.
Any ideas?
Bardos59
#2 Posted : 9 years ago
Rank: Guest
Groups: Guests
uninstall, do a registry clean...if you do not know how to do that, I suggest you get someone to do it for you, or you can take the risk and do a google search for how to do it .....then reinstall vMix.....that should fix it, and if that does not fix it, do a system restore....I would do a system restore to a date when it worked .......
kjones9999
#3 Posted : 9 years ago
kjones9999
Thanks for the reply.
I uninstalled a recently installed C++ distributable and it solved the problem.
