otkim
#1 Posted : Thursday, January 21, 2016 4:44:52 AM(UTC)
otkim
FYI
vMix User Guilde says in order to cut preview to output, use 'Input.Preview.Function("Cut")' command.
But it never works for me.
By surveying this forum, I found how to select 'Preview' or 'Output' in VB script.(Indirectly)
The following is the code.
Dim doc As New XmlDocument()
doc.LoadXml(API.XML())
Dim id As String = doc.SelectSingleNode("/vmix/active").InnerText
Dim node As XmlNode = doc.SelectSingleNode("/vmix/inputs/input[@number='"+ id +"']")
Dim name As String = node.FirstChild.InnerText
Input.Find(name).Function("SetZoom", "+=0.05")
#2 Posted : Thursday, January 21, 2016 7:25:35 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Yes, sorry about that, there is a bug that crept in that prevents Input.Preview from working properly.
It will be fixed in the next update.
jhebbel
#3 Posted : Thursday, January 21, 2016 7:45:07 AM(UTC)
jhebbel
While looking at those classes, is it possible to expose through abstract the input properties of the program and preview classes? That way parsing or deserializing an xml would not be necessary to retrieve input props and fields?
