Newbie question about single audio source to a mix..
I'm sure this question has already been posted somewhere but...
Is-it possible to have a mix of let's say 3 video sources (ex: 3 cameras) and tell vmix to only use an external connected stereo audio feed without using any of the cameras original audio ? This would be use to record a music show with these cameras but record the audio from the theatre audio mixer's stereo output..
If so where are the settings to do so in vMix v14 ?
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ jpdesrocp
The simple answer is yes, you can have an "Audio" input that can be set to 'always ON' so to speak, provided you have the means to "capture" your audio device such as an external mixer. The settings haven't changed much for any edition of vMix since the introduction of the "Audio Mixer" feature. (You should be taking advantage of all of vMix's latest features by updating to the latest release). De-activate the double arrow icon (audio follows input) and activate the Speaker icon (Audio ON). If your cameras have an audio feed that you don't want to hear you can turn their levels down (best) or set them up to not "Automatically mix audio" in settings or select "None" as the 'Audio Device' when adding it as an Input.
