Digitalson
#1 Posted : Monday, January 18, 2016 12:41:31 PM(UTC)
Digitalson
Groups:
You can only add up to 4 overlays with any input right?
#2 Posted : Monday, January 18, 2016 12:55:25 PM(UTC)
@ Digitalson
There are only 4 channels for DSK (Down Stream Keying) directly over the 'Program' output.
However, there are two additional channels for 'Stinger' Overlays and 5 channels for keying within the 'MultiView' feature USK (Up Stream Keying).
Although, layering is limited to two levels when attempting to combine Inputs with 'MultiView' Overlays.
Hope that helps,
Digitalson
#3 Posted : Monday, January 18, 2016 4:48:43 PM(UTC)
Digitalson
Groups:
Do you mean the the pip ,I was able to add 4 videos in there ,there are 5 inputs avalible ,and there are 2 of them ? Right
#4 Posted : Monday, January 18, 2016 8:12:47 PM(UTC)
@ Digitalson
Well sort of...
Each overlay channel of the 'MultiView' feature is independently configurable (size, location etc.)
The PiP presets (Scrollable window beside the 'Position' buttons) are exactly that "presets" that can be modified but are a quick and easy way to set-up PiP configurations.
You can even add your own "presets".
