Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Hi!
I'm making this thread in hope of getting some of the issues I've as well as some others on the forums has met adressed and/or fixed, so here's my list:
Benchmark is pretty much setting up a ticker on top of the XAML and making sure its running perfectly smooth as vMix FPS counter won't show the FPS of the XAML maybe due to it being another engine or something. Martin might have some more info on that one.
Also, PC Specs of mine are a i7-3960X and a GTX 670 that isn't being capped at all, usually almost idleing.
Issue #1 (Performance): PNGs in XAML
PNGs in XAML were extremely laggy to the point that adding a 1x1 png in an empty XAML used 10% CPU, also, animating them took lots of CPU. It seems now that the CPU usage has gone down but still, when adding it to a XAML with an animation/ticker causes it to stutter to probably half the FPS.
I "fixed" this by rendering graphics out in vector format and adding them as shapes within Blend, but this is surely not possible for all graphics and is really inconvenient.
Issue #2 (Performance): Shadows in XAML
Animating text with shadows is really a CPU killer without really being it. It seems to me like a XAML (or maybe a input in vMix regardless) is limited to around 10% CPU usage and I do not know if it is this 10% that cannot handle animating text with shadows but it surely is laggy.
Issue #3 (Bug): Images stop refreshing
Somewhat randomly, when a rectangle fill is bound to a text box it will stop refreshing the image after a set time. It doesn't seem to have anything to do with animations or anything and it stops after around 5 minutes of use. It will only get fixed if you reset the input by "changing" it to the same XAML
Any input on this and/or hotfixes would be great!
Cheers, Håvard
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Could you post some sample XAML files with the necessary images in a zip file for some testing?
vMix pretty much renders XAML files directly using WPF, without any restrictions or CPU limiting. It does however have to use the WPF software renderer as the GPU renderer does not play well with other Direct3D programs. This can lead to high CPU usage for graphic intensive stuff, so best to keep titles as simple as possible.
Martin vMix
Just encountered this problem again and remembered the thread, sorry for late reply, here's an example File Attachment(s):  examples.zip (3kb) downloaded 25 time(s).You cannot view/download attachments. Try to login or register.
