Feature Requests
Ability to select which Input to remove input via API
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Would be nice to have the ability to select which Input to remove when using the RemoveInput command in the API and not remove always the last Input....
eg.
If 5 inputs are loaded, have the ability to remove Input 3...
RemoveInput&Value=3
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Do you perhaps have an old version of vMix? The Help fort shortcut RemoveInput includes which Input as a parameter. Eg: RemoveInput&Input=3
Feature Requests
