Hello Friends My problem Vmix on not getting rtsp ip camera video camera model is Tiandy TC-NH9606S6-2MP on-CW VLC getting player image but vmixt I'm having trouble 401 Unauthorized error gives an rtsp: // user: pass@xx.xxx.xxx.xx/ this so he can not accept. How can I solve this problem? Thanks in advance for help .. ceycey79 attached the following image(s):  problem.jpg (211kb) downloaded 16 time(s).You cannot view/download attachments. Try to login or register.
Groups: Joined: 5/24/2014(UTC) Posts: 56 Location: Russia
If this camera in you private network - may be you disable authorisation for rtsp stream in web-interface on cam ?
homeless wrote:If this camera in you private network - may be you disable authorisation for rtsp stream in web-interface on cam ? I could not find such a split inside the camera.
Search settings for RTSP - port number... usually near exist checkbox "Enable RTSP Authentication" or - search "allow anonymouse view"
