Joined: 6/11/2012(UTC) Posts: 41  Location: jakarta Thanks: 35 times Was thanked: 12 time(s) in 7 post(s)
Rank: Guest
Groups: Guests
I tried the sample, and it does not load, and locks up vMix for over 2 mins
 1 user thanked kayllastudio for this useful post.
@ kayllastudio
Thanks for sharing, although there does appear to be an issue with the animation "in"... (it needs to be re-started and played manually to animate "in" otherwise there is no image until you remove overlay and suddenly it appears and animates "out")
Rank: Guest
Groups: Guests
How can this sample be modified, other than just changing the names
IceStream wrote:@ kayllastudio
Ice This is indeed a complex graphic designs. It is advisable to wear a slightly higher graphics card and install dotnet framework 4.0
@ kayllastudio
I don't deny the complexity of your designs, you've done some incredible work, I'm just trying to help and point out to you and others that your sample did not behave as expected for me and I'm just trying to figure out why. To the best of my knowledge, my system is running Framework 4.0 unless somehow Upgrading to Windows10 reverts back to 3.5 but I will look into that. Do you have a minimum standard or specs on which graphics cards are best suited for your designs, although mine is not the most current, it has served me well (gtx 470). If we are able to accurately ascertain what is causing the issue, it may very well save you a lot of aggravation down the road with customers who need your products to perform well for them from the get go. Surely I am not the only one to have this issue...
Update:
It would seem "my" issue is not isolated to this "Sample" animated XAML file, but rather animated XAML titles in general (at least the ones I have tested). Not sure if this is a "BUG" with vMix 16.0.0.114 or some anomaly from the most recent Windows 10 Update... Even the 'included' vMix animated lower third exhibits the same behavior, it does not animate "in" when 'Overlayed' with a DSK (buttons 1,2,3 and 4). The animated XAML's do however animate "in" just fine when used within the "MultiView" feature (the issue there is that they can't animate out, or at least I have not figured out how yet). I will investigate further when I have more time, but in the meanwhile I will post this possible "BUG" elsewhere in the forum.
IceStream, And with me is the same problem.
for what it is worth
no animation problem with said titles: vMix 16...114 windows 7
Guy
SOLVED: Thanks to Martin for pointing me in the right direction. It would appear this is because of a couple "Settings" boxes not being ticked in vMix. Firstly, in "Master Settings" (Settings/Options): * Automatically Play Output Input with Transition * box needs to be ticked (something I did not look for when originally testing, please note that this will require vMix to Restart to adjust) Secondly, in 'Input' "Settings" (cog wheel): * Automatically Play with Transition * box needs to be ticked (this is where I first looked to no avail and why I thought it might have been a "BUG") Once again, kudos to kayllastudio for designing some great animated XAML packs and sharing this 'Sample' graphic with the community. For anyone interested in acquiring some of these graphics packs, you can check some of them out here: https://www.youtube.com/user/kayllarecord1/videosIt is probably best to contact KAYLA through email: kayllastudio@gmail.comIce
Thank you my friend, you are my best friend. Thank martin has made a great and amazing software.
Go out for a second and disappears.Whether it should work.
I'm really liking what you're doing with these Kaylla. How does one go about getting these?
I have the same problem with the sample as well as another title pack. I'll assume they have the same cause. I've ticked and unticked every box possible and still not solving the problem. I have .net framwork 4.6 windows 10 nvidia video card. Are there any other suggestions on what I can do to make this work properly?
OK I have tested the titles on another system and they work as expected. Does anyone have any idea what could be causing them to not display correctly on my main computer?
Was thanked: 4 time(s) in 1 post(s)
 4 users thanked anselm for this useful post.
ask on 7/25/2016(UTC), fLipz on 10/26/2016(UTC), J'chap on 11/1/2016(UTC), Harty on 1/3/2017(UTC)
