Scoreboard Soccer graphics pack and multiple use of shortcuts
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
I made my own scoreboard template. I will make some showcase here on youtube video for vMix. I have one question: Is it able to take the same values of scoreboard for another design/scoreboard, everything on same project? Explanation: So, I have top left scoreboard with short team names, score and timer. And like on TV soccer production I wanna show bottom middle scoreboard (every 10-15 minutes) with full team names, score, logos and timer. The point is that I dont need to update 2 scoreboards, just to update one, and on another the timer and score updates automatically? MADE THISWith this I am thinking to make player list (with bench) for both teams, coach names, judges... MADE THIS, EXAMPLE IN THE BOTTOM OF POSTAnd if someone coulf explain me easily how to make that on scoreboard extra time and background for it is empty until I add extra time value (+1,+2,+5 etc) when it shows up with some animation? I FIGURE IT OUTEDIT: This is a video example what I made: https://www.youtube.com/watch?v=sG07dQaYjs8thx
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ Siroki
If I understand you correctly, I would do this with additional 'Shortcuts' for your second scoreboard and then add them to the "Advanced" tab of the 'Shortcuts' you use for your first scoreboard. That is, for example, the "Start Timer" shortcut for your first scoreboard triggers the "Start Timer" for the second scoreboard, so they will always be in sync.
For adding an animated "Extra Time" timer, I would be inclined to do this independently as a workaround, similar to how I do a "penalty" clock in hockey, unless you have the programming skills to develop your own XAML animation "in" of a secondary timer once the primary maxes out (i.e. at 45 mins and 90 mins)
IceStream wrote:@ Siroki
Thank you for answer. I am new in vMix, just intalled it today, bought a HD licence. I tryed some shortcuts for startTimer (F1) and score raise (Add) but didn't get it right. Not really shure how to make it, need to read and see some tutorials. You recommend to use the same shortcuts for timer in both modules? I was thinking to insert like p-in-p/overlay the small (top left) scoreboard on the second one, use the same background image for score and time and just crop it few times and put on right place. Thar was my idea. I don't have programming skills, I am a graphic designer, know html,css etc but not programming to make some XAML animation. Can you explain or send some tutorial for your suggestion: independently as a workaround, similar to how I do a "penalty" clock in hockeyDou you have example? Thanks Marko
@ Siroki
My apologies Marko, perhaps I mistakenly thought your graphics were already XAMLs that you were able to use with vMix. If not, it's no big deal, you can easily use the vMix Titler to create your own using some of your existing graphic elements (although as a graphic designer you might not like the "basic" UI, but with a little patience I'm sure you'll manage just fine). Another option might be to acquire an already existing vMix XAML sports graphics/titles pack. (If you search the forum you can probably find 3 or 4 different ones, when I have more time, I'll see what I can dig up)
Tips for shortcuts: To increase score by one use value: +=1 To start a timer I prefer to use the "pause" function for "start/stop" scenarios.
Thanks I was working on graphics and this is what I made past days:  Custom graphics with almost everything, good for amateur/professional soccer stream (I think so :)) No animations, but with vMix animations on overlays in looks very professional. I will make a video with my graphics when I prepare everything. thx Marko
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
It's pretty crude, but here's a quick tutorial I made on how to use shortcuts to advance the scores on a scoreboard and how to use the same data on more than one scoreboard. ?t=18m59s The video starts at about 19:00 with the "adding same data" part. Hope this is helpful! - Tom
Thanks guys but I manage to do everything today with vMix standard transitions and vMix title designer..Looks awesome..I need to finish penalties and intro with info and logos and I will make small video presentation of it and put it here.
The solution for scoreboard are shortcuts +=1 -=1 for score count
and startCountdown and pauseCountdown
The solution for extra time is that I made custom title with just background, +, and editable value. Put module for extraTime, enter i Scoreboard module, made Multiview (Overlay), choose extra time and set it to place. Later I made shortcut for up and down value of extra time (depends on referee decision) and shortcut to overlay it and remove it. It works great. Xou will see on my video example when I finish everythig, possoble tommorow.
For second timer on bottom middle scoreboard I just put Multiview, on position one put scoreboard, crop the timer and put it on the right place. Works fine :)
bye Marko
Siroki wrote:Thanks I was working on graphics and this is what I made past days:
thx Marko Will you make avaliable this graphic package? free or pay? Thanks Lukas
Kalink wrote:Siroki wrote:Thanks I was working on graphics and this is what I made past days:
thx Marko Will you make avaliable this graphic package? free or pay? Thanks Lukas I would give it for free just not shure how to do that? To zip everything with vMix saved project or? Or XAML files with graphics? I did everything in title designer on 1280x720
sinc747 wrote:It's pretty crude, but here's a quick tutorial I made on how to use shortcuts to advance the scores on a scoreboard and how to use the same data on more than one scoreboard. ?t=18m59s The video starts at about 19:00 with the "adding same data" part. Hope this is helpful! - Tom Hi Tom, I figure this by myself already before I saw your post. Like I explain in my earlier post. It works fine. I just add a timer on second scoreboard on way that I put a first scoreboard on multiview on second and crop the timer, put it on place and it works like a charm :) I will put a video example of my soccer graphics as soon as possible Marko
Siroki wrote:Kalink wrote:Siroki wrote:Thanks I was working on graphics and this is what I made past days:
thx Marko Will you make avaliable this graphic package? free or pay? Thanks Lukas I would give it for free just not shure how to do that? To zip everything with vMix saved project or? Or XAML files with graphics? I did everything in title designer on 1280x720 I really dont know, possibly XAML files and project...did you also made some shortcuts for it? 1280x720 is not a problem. Thanks!
 1 user thanked Kalink for this useful post.
Kalink wrote:Siroki wrote:Kalink wrote:Siroki wrote:Thanks I was working on graphics and this is what I made past days:
thx Marko Will you make avaliable this graphic package? free or pay? Thanks Lukas I would give it for free just not shure how to do that? To zip everything with vMix saved project or? Or XAML files with graphics? I did everything in title designer on 1280x720 I really dont know, possibly XAML files and project...did you also made some shortcuts for it? 1280x720 is not a problem. Thanks! yes I made shortcuts for start/pause countdown, +- score, +1- extra time with shortcuts to transition show/hide You will see everything in my video when I make it during next days
 1 user thanked Siroki for this useful post.
