Squier
#1 Posted : Tuesday, December 15, 2015 2:58:23 PM(UTC)
Squier
Hi, I'm new to Vmix and would like some advice on an sdi output card. I have Magewell 4 sdi input card, can I use an output card from any vendor on the pc (or do you have to stick to the same as the input card)?
If so, do you have any suggestions (1 x sdi out)?
S
Ittaidv
#2 Posted : Tuesday, December 15, 2015 3:44:59 PM(UTC)
Ittaidv
S
You can use any brands of cards and mix/match them as you wish. The blackmagic mini monitors are good and cheap ones with sdi output.
thanks 1 user thanked Ittaidv for this useful post.
Squier on 12/15/2015(UTC)
