Hello , I need to do a countdown dated day . hours and minutes for an event and it then appears during transmission
@ alexchamo
I do not believe you can do this with the built in vMix XAML Timer feature (only hours/minutes/seconds) But there are a ton of "on-line" timers that you could possibly use and do a screen capture if that works for you...
