Feature Requests
Add checkbox "reverse" for overlay transition ( slide and vertical slide/wipe)
Hi, it could be very interesting if u add a checkbox "reverse" in overlay section ! I mean, with this checkbox we could change the input transition for slide and vertical slide/wipe from top to bottom TO from bottom to top and from left to right TO from right to left !
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
I think such a thing would have to be done in the xaml and isn't really dictated by the program at all.
@ Element III
Not sure I fully understand. The 'Overlay' transition already "reverses" out, which is kinda what you should want it to do... Sounds like you want an option to change the "In" and "Out" transitions mid stride, is that correct? Or do you simply want more transition options?
Element III wrote:Hi, it could be very interesting if u add a checkbox "reverse" in overlay section ! I mean, with this checkbox we could change the input transition for slide and vertical slide/wipe from top to bottom TO from bottom to top and from left to right TO from right to left ! +1
IceStream wrote:@ Element III
Ice As I read it, they simply want to change the direction from which the overlay animates from. RTL becoming LTR.
yeah that it i just want change where the overlay appear. when u choose an transition in overlay section like Slide, when u click on the overlay the in is only left to right and if u add a checkbox reverse this same overlay can appear from right to left .
+ 1
For more & customizable transitions
Feature Requests
