Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi
Would it be possible to add a shortcut function similar to the SetCountdown function which affects the Duration under the Countdown Settings but for the Start Time also in the Countdown Settings dialog. If it is possible how about the Display Format and Reverse CheckBox as well
Thank you Ash
The Countdown only works for the first element of the XAML file. Can this be fixed ? Also When you stop the Countdown is always shows the end of the duration not the beginning. i.e. you want to start from 00:00 but the Countdown shows 10:00 until the timer is started.
Agree that extra API calls would improve this feature to control remotely.
+ 1
@ adamstanton
My "workaround" for the start/stop time display is a quick double click of the "Pause" button (essentially a start and stop before the first second passes). Not exactly a one step 'reset', but works well for me.
