2 Pages12>
#1 Posted : Tuesday, July 10, 2012 5:52:11 AM(UTC)
Was thanked: 4729 time(s) in 1621 post(s)
The test version of vMix 2012 v4 is now available for download:
http://www.vmix.com.au/download/vmix2012v4.exe
(Updated 13 July 2012 with version 7.4.0.45)
Please note this is a test release and any bug reports should be submitted here.
Of particular note is the new "vMix Audio" device which allows recording of just the audio within vMix.
Reports on how well this works on various sound cards would be appreciated.
Release Notes:
NEW: Virtual Sets - Use live chroma keying to place talent in animated 3d virtual sets
NEW: vMix Audio device records only the audio within vMix instead of the entire system
NEW: Full 64bit support
NEW: Many additional Shortcut Functions added
NEW: Web based API
NEW: Video Delay can be assigned to Capture Input
NEW: Short clips up to 1 minute in length can be saved from Video Delay
NEW: Playback speed of video sources can be set from right click menu
NEW: Option to force all inputs to use the global frame rate
NEW: PNG option added to Desktop Capture
NEW: Save image captures to file with the Photo Snapshot button
NEW: BOB Deinterlacing option added to Capture. Doubles frame rate to preserve motion.
NEW: Text Presets can be configured for Titles and accessed from right click menu
NEW: Automatic parsing of YouTube and Vimeo videos in Flash Input
NEW: Overlay can be triggered from PlayList
NEW: Additional resolution options added for External Output and Recordings
NEW: Additional bitrate options added to MPEG-2
NEW: Play/Pause button added for each input
FIXED: Freezing for up to 5 minutes may occur when Windows reports UI changes
FIXED: Recordings now compensate for audio devices that provide incorrect timestamps
FIXED: HDV inputs may have dropped frames
IMPROVED: Windows 8 supported
IMPROVED: Audio Mixer now docks within the main window
IMPROVED: Title Ticker cpu usage halved
IMPROVED: Improved position accuracy within Input Settings and Overlay Picture In Picture
mh166
#2 Posted : Tuesday, July 10, 2012 6:41:58 AM(UTC)
mh166
That's amazing. Can't wait to try it out!
Unfortunately, by now, I can't: the download link is not working. Could you check this out?
Thanks and regards,
mh166
#3 Posted : Tuesday, July 10, 2012 7:10:48 AM(UTC)
It is currently uploading, please try again in an hour or so.
melody
#4 Posted : Tuesday, July 10, 2012 7:38:37 AM(UTC)
Rank: Guest
Groups: Guests
hi,
i downloaded this v4 test and i realy need to say that you martin have made an HUGE work on it. now i have my 2 firewire sony cams at 1080p both without any drops.
just founded some "bug". i`m using Basic HD edition and when loading my HD sources from profile it says that edition does not support the resolution. after this message, simply added the inputs with 1080p resolution and works fine.
these hdv fix and 1024x576 resolution are so much apreciatted here martin, thank you very very much.
at once, it`s all working stable with mixing, recording and streaming.
regards,
melody
www.espiritosanto.cc
Tagore
#5 Posted : Tuesday, July 10, 2012 12:23:22 PM(UTC)
Tagore
Hi we want to test the virtual set feature and give me :
"Arithmetic operation resulted in a overflow"
that happen when try to add the input ( the virtual set ).
Best regards and thx for all your hard work.
#6 Posted : Wednesday, July 11, 2012 2:16:52 AM(UTC)
I have updated the download to 7.4.0.38 to fix the following issues:
1. Fixed Virtual Set issue in regions where a comma is used as a decimal point
2. Fixed aspect ratio issue when using Virtual Sets in a non-widescreen setup.
The download is the same as before (see first post in this thread)
melody
#7 Posted : Wednesday, July 11, 2012 5:45:56 AM(UTC)
Rank: Guest
Groups: Guests
hi martin,
some bugs founded in v4:
1. testing v4 x64, some exception message has showed me when opening vmix v4 x64 only... see the image below...
http://imageshack.us/pho...es/16/vmixexception.png/
full text information:
Consulte o fim desta mensagem para obter detalhes sobre como invocar a depuração
JIT (just-in-time) em vez desta caixa de diálogo.
************** Texto da excepção **************
System.Configuration.ConfigurationErrorsException: Secção de configuração desconhecida userSettings. (C:\Users\IESCC\AppData\Local\StudioCoast_Pty_Ltd\vMix2012x64.exe_Url_fns0zmgsk05swvszvrc3qcvdpeurs4fi\7.4.0.38\user.config line 3)
em System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
em System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
em System.Configuration.ClientConfigurationSystem.OnConfigRemoved(Object sender, InternalConfigEventArgs e)
************** Assemblagens carregadas **************
mscorlib
Versão da assemblagem: 2.0.0.0
Versão Win32: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
vMix2012
Versão da assemblagem: 7.4.0.38
Versão Win32: 7.4.0.38
CodeBase: file:///C:/Program%20Files%20(x86)/vMix2012/vMix2012x64.exe
Microsoft.VisualBasic
Versão da assemblagem: 8.0.0.0
Versão Win32: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
Versão Win32: 2.0.50727.5460 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Versão Win32: 2.0.50727.5462 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Versão Win32: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
SlimDX
Versão da assemblagem: 2.0.13.43
Versão Win32:
CodeBase: file:///C:/Program%20Files%20(x86)/vMix2012/x64/SlimDX.lib
ComponentFactory.Krypton.Toolkit
Versão da assemblagem: 4.3.2.0
Versão Win32: 4.3.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/vMix2012/ComponentFactory.Krypton.Toolkit.DLL
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
system.configuration.resources
Versão Win32: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration.resources/2.0.0.0_pt_b03f5f7f11d50a3a/System.Configuration.resources.dll
mscorlib.resources
Microsoft.VisualBasic.resources
Versão Win32: 8.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic.resources/8.0.0.0_pt_b03f5f7f11d50a3a/Microsoft.VisualBasic.resources.dll
System.Windows.Forms.resources
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_pt_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Depuração JIT **************
Para activar a depuração just-in-time (JIT), o ficheiro .config para esta
aplicação ou computador (machine.config) tem de ter o
valor jitDebugging definido na secção system.windows.forms.
A aplicação também tem de ser compilada com a depuração
activada.
Por exemplo:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Quando a depuração JIT está activada, qualquer excepção não processada
será enviada para o depurador JIT registado no computador
em vez de ser processada por esta caixa de diálogo.
2. loading preset resolution error persists, mentioned in my last post above. report error has been sended. i`m using Basic HD Edition.
however, v4 x86 is working fine with no issues.
regards,
melody
#8 Posted : Wednesday, July 11, 2012 6:40:09 AM(UTC)
Melody,
Looks like the configuration has been corrupted.
Could you please email info@vmix.com.au the following file:
Also email through the preset file you are trying to open.
melody
#9 Posted : Wednesday, July 11, 2012 11:29:16 AM(UTC)
Rank: Guest
Groups: Guests
sended.
#10 Posted : Wednesday, July 11, 2012 11:35:52 PM(UTC)
Thankyou.
A new update is now available (7.4.0.39) (same download link as before) with the following fixes:
1. Fixed resolution error for HDV sources.
2. Fixed corrupt user.config issue in 64bit version.
melody
#11 Posted : Thursday, July 12, 2012 5:42:20 AM(UTC)
Rank: Guest
Groups: Guests
hi again,
thank you for updates but still giving me an error message.
vmix shows me some message about deinterlace method (bob) does not support vmr and dont load cameras, but i have not ticked vmr option. error report sended.
when i load cameras manualy, after select source options, i need go "i" and tick manualy the deinterlace option. deinterlace method is not loading with the source. this only occours when i choose bob deinterlace.
i tried the blend deinterlace method and no errors on saved profile. vmix load all inputs with no problems.
i can provide some more information, if necessary, to fix the problem. thank you again for updates,
regards,
melody
#12 Posted : Thursday, July 12, 2012 6:44:49 AM(UTC)
Hi Melody,
Bob Deinterlacing is not supported for HDV as the deinterlacing is already done by the HDV codec.
(And is usually Bob Deinterlacing or better anyway)
dundurs
#13 Posted : Thursday, July 12, 2012 6:58:03 AM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
Hello, Martin,
Some feedback on great new video delay capabilities:
1. For video delay input please add additional option (default) in dropdown “Original” that would Save the original length of video delay. For example, if I have chosen to use 7sec delay, I would also like to be able to save 7sec delay and not only 10sec delay that keeps looping the 7sec delay.
2. Can you make it possible to use video delay while Saving it? At this point we see a black window when trying to use video delay that is being saved.
3. Can you change the default title for video delay to "input_name_time_date" (so that time is visible in title and its easier to identify the recording)?
4. Can audio also be recorded for recordings? (master audio)
5. At some point I noticed video delay time of 23.96 sec instead of chosen 20 sec in preview window, which doesnt seem right.
6. At some point video delay in preview or input windows shows the real-time video and not the delay, which is not good. Previously we were able to see the delayed video in video input also in Preview and input windows.
Also I got a blue screen when running the test version for the second time and trying to add new input - hauppauge usb live 2.
Any chance we can get checkboxes in Options to autostart and autofullscreen? This would help a lot for unattended vMix installations in case the computer gets restarted.
Thanks,
Dundurs
#14 Posted : Thursday, July 12, 2012 7:39:52 AM(UTC)
Hi Dundurs,
Some comments on a few of your points:
6. By default the Video Delay now sets the position to "real-time" but you can change this by dragging then position bar when in preview.
Blue Screen: Blue screens are almost always caused by bugs in the capture driver, so I would suggest looking for a driver update for the hauppauge usb live 2.
CheckBoxes: There is an option to autofullscreen in vMix settings under Options. ("Automatically start maximised")
You can also place a shortcut to vMix in the windows startup folder:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
I will look into adding the other suggestions you have made.
Thanks,
dundurs
#15 Posted : Thursday, July 12, 2012 7:44:17 AM(UTC)
dundurs
I actually meant "start automatically external" so that vMix virtual device is ready to be used.
dundurs
#16 Posted : Thursday, July 12, 2012 7:48:24 AM(UTC)
dundurs
I think it was better previoulsy when by default we could see the delayed video. The real-time video can be seen in the corresponding video input so there is no need to duplicate this video.
Famous Pictures
#17 Posted : Thursday, July 12, 2012 2:10:37 PM(UTC)
Famous Pictures
Hoping you will consider the RECORD and STREAM status indicators as mentioned in my previous messages. Only showing the setup/start and green stop buttons can be confusing. A few times we thought we were recording but weren't and lost the show.
Mauro Cesar
#18 Posted : Thursday, July 12, 2012 4:25:13 PM(UTC)
Mauro Cesar
Tips for Testing and version 4:
1-Error loading even with Matroska Video "Haali Media Splitter" installed:
CVR
AddNewInput.CVR
The operation can not be performed because the pins are not connected.
2-Pressing the button "overlay 1 to 4" to create the same PIP video is pausing the image
3-Configuration "overlay" the parameters of rotation "X, Y, Z" does not change the image in red in real perspective that will be the PIP. The result is only seen when the PIP is applied.
4-Videodelay When saving a file is loaded in a new window. Tip: Save the first in a window "playback-delay" and the next file on a button "Combo box".
5-Create "Virtual Set" more layer "talents" to use more cameras.
6- When "Sharpen" is triggered deinterlacing is bad.
Sorry if I repeated tips already reported.
regards,
Mauro
#19 Posted : Thursday, July 12, 2012 10:28:19 PM(UTC)
Famous Pictures,
Could you provide some suggestions on what the record indicator would look like and where it would appear?
Mauro,
1. What video format are you trying to load?
2. Can you describe further what is happening here?
6. Sharpen is not supported with deinterlacing due to graphics card limitation.
Famous Pictures
#20 Posted : Friday, July 13, 2012 1:46:33 PM(UTC)
Famous Pictures
Suggested changes:
1) Move transition buttons to the left.
2) VU meters side-by-side. Most professional audio equipment does not separate left and right channels. Having left and right meters next to each other makes it easier to match L and R input levels to a test tone.
3) Remove the text "Recording". Rename the "Setup" button to "Record Setup". Seeing the word "Recording" could indicate a recording is in progress.
4) Add red "Recording" indication when recording is in progress. It would not appear when there is no recording in progress.
5) Add red "Streaming" indication when external streaming is in progress. It would not appear when there is no streaming in progress.
What do you think?
Guest (4)
2 Pages12>
