Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I was a count up timer on a title graphic that start 1 zero and stops after 45 minutes at 45.
I would like a web button that starts and stops timer.
This is all easy to do.
I would then like to be able to then do is restart the clock for the second 45 minutes.
So I have a web button that changes the duration of the timer but not matter if i use a pause / resume or a start button it always goes from zero again. HELP!
As an note it would be nice to also understand what you can do in {} with regard times
Thanks as always for a great piece of software!
@ smudge1977
Not sure I fully understand your post... I can only assume that you are happy with your 'timer' set-up, except that your second 45 minutes does not count up from 45 to 90, is that correct? AFAIK, there is no 'master' setting that will do this automatically, you will have to manually adjust your 'timer' settings during the break (in your case change the "Start Time" to '00:45:00').
Thanks: 23 times Was thanked: 13 time(s) in 10 post(s)
setup two timer inputs. one that counts from 00:00 to 45:00, then another one that counts from 45:00 to 90:00. once you stop the original timer, you can switch the second timer into that overlay slot. because both should be at 45:00, the viewer will not notice the change.
