Overlay and SlideShow restarts possible bug
I'm not sure if this is a bug or not, but it took me a while to figure out, and I'm not sure why it behaves this way. I tend to use the 'Multiview' feature extensively, often using a folder of Images or graphics as the 'Photos' input to be used as one of the overlay channels. Sometimes I need to cycle through the images with the 'SlideShow' which works fine. At other times, I only need one of the images, such as a logo or corner bug, which also works fine as long as I set things up appropriately (desired image chosen and '0' Seconds set as the "Transition" time in 'SldeShow Settings'). However, I came across this 'BUG' when I inadvertently pressed one of the 'Overlay' button (1,2,3,4 DSK) for one such 'MultiView' input; All of a sudden, the 'desired image' reverted to the first image in the folder (or first image of the 'SlideShow'). This happens when the 'Input' is set to "Automatically Play with Transition" (which is my default setting for most 'Inputs'). It's not a big deal for me as I know there are many workarounds and I tend not to use the DSK buttons a lot, but I did come across it by accident and I am not exactly sure why it does that only when "overlayed".
Any insights as to the purpose or application are most welcome.
Thanks.
