Ken_Adams
#1 Posted : Tuesday, November 24, 2015 7:16:52 PM(UTC)
Ken_Adams
Hi, I 'm new with Vmix , I took several days mulling over a problem.
I do not get activated more than 1 camera, instantly replay , I get the camera 1 to select between my camera , but the 2 3 and 4 off, 2 3 and 4 work perfectly in the live.
Any solution , thanks.
#2 Posted : Tuesday, November 24, 2015 7:45:17 PM(UTC)
@ Ken_Adams
I hate making assumptions, so maybe you can provide a few more details...
What version of vMix are you using?
Can you provide a screen shot of the 'Instant Replay' selection window and the issue you are having in choosing cameras?
linroot
#3 Posted : Wednesday, December 23, 2015 10:07:36 AM(UTC)
linroot
Hello, have the same problem.
Vmix ver 16 PRO
Have add 2 cameras to input
ptv
#4 Posted : Wednesday, March 16, 2016 4:36:54 PM(UTC)
ptv
i have the same problem, any solution??
Cpilcher
#5 Posted : Wednesday, March 16, 2016 8:41:12 PM(UTC)
Cpilcher
I only have vMix 4K so I can only run 1 camera replays. But... I do have trouble changing the settings when there is a different replay profile (not sure the correct term) loaded from before. I have to delete the contents of my replay folder (the saved replay settings) before I can select certain options. Maybe that has something to do with it? Does it do this with a fresh replay input?
fundownunder
#6 Posted : Saturday, October 29, 2016 12:00:47 AM(UTC)
fundownunder
Groups: Guests
Hi all,
in the same boat with regards to only being able to select 1 camera.
Running two Intensity Pro cards. Can bring both in as a 'live source' but can only select one in IR.
Any advice.
Cheers.
sinc747
#7 Posted : Saturday, October 29, 2016 12:24:45 AM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
What edition and version of vMix are you using? Edition = Pro? Version = 17.0.0.112?
- Tom
fundownunder
#8 Posted : Saturday, October 29, 2016 12:34:45 AM(UTC)
fundownunder
Groups: Guests
Hi Tom,
vMix Pro 17.0.0.107
ask
#9 Posted : Saturday, October 29, 2016 12:45:56 AM(UTC)
ask
@Fundownunder...
Try deleting everything in the Replay recording folder or specify a new location. Then restart vMix, add a IR input and see what you get. Have just tested here on three systems and all works fine.
sinc747
#10 Posted : Saturday, October 29, 2016 1:46:52 AM(UTC)
sinc747
Yep, what ask says for sure. Also, you should update to 17.0.0.112.
- Tom
fundownunder
#11 Posted : Saturday, October 29, 2016 2:26:07 AM(UTC)
fundownunder
Groups: Guests
Thanks sinc747 and ask for replying so quickly.
I'm still troubleshooting for what ask recommended didn't work for me.
Could it be because I'm not saving to a SSD?
Maybe on this PC the graphics card is under spec'd. It's an AMD Radeon HD 7700 Series
That said I have another PC with a Nvidia GeForce GTX 960 graphics card with a Blackmagic Decklink Duo. I can see both live SDI sources but still only a single camera in IR.
Cheers
ask
#12 Posted : Saturday, October 29, 2016 7:02:34 PM(UTC)
ask
fundownunder wrote:
Hi Tom,
vMix Pro 17.0.0.107
Can you post a screen shot of the top left hand corner of your screen? Regards. Andrew
skadi
#13 Posted : Sunday, June 13, 2021 3:09:05 AM(UTC)
skadi
Russian Federation
1
the same problem in 24.0.0.51
deleting all do not work
closing replay
trying to create new replay
restarting vmix
restarting pc
these all does not works.
xaver
#14 Posted : Sunday, June 13, 2021 3:28:50 AM(UTC)
xaver
do you have pro or 4k version?
skadi
#15 Posted : Sunday, June 13, 2021 5:36:50 PM(UTC)
skadi
Russian Federation
it is 4k version
cams are 1080@50p
it was working ok till yesterday
also have tried reinstalling declink desktop drivers
reinstalling vmix
upd: installing trial solves the problem.
very strange to get it stop working just before the live.
Radiotvpat1982
#16 Posted : Monday, June 14, 2021 1:28:18 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
The answer for this one is easy.
If you have a 4K licence and not a Pro you are limited to 1 angle.
If you were previously on a trial you were granted a temporary Pro licence. Upgrade to pro and your all good to go!
