Hello everyone, I should create a motion graphics type compose a sphere acquiring an image from the remote desktop, how can I do? thank you
@ mixsystem
This sounds like a pretty sophisticated Special Effect and I don't think it is something that you can 'create' with vMix. Perhaps you can explain a little more elaborately or provide a link to an example of what you want and someone can point you in the right direction of how best to accomplish it.
I would like to achieve something, the graphics of the beginning
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
Thats a lot of random 3d work and video effefts put in 40 sec. if you'd actieve the first 40 sec i'd suggest hire somebody who van make it for you or learning a lot about 3d software like cinema 4d. However I think you need to adept yourself to other needs
@ mixsystem I agree with TVIason that this would be a very ambitious project to take on and learn to do yourself, but if you are up to the challenge, I would suggest starting with a program like 'Blender' which is a professional free and open-source 3D computer graphics software product used for creating animated films and visual effects. http://www.blender.org/It will give you a good idea of exactly how complex the whole process of designing 3D animation is to learn and master without having to 'invest' or commit to buying similar software like 'Cinema 4D'. A simpler option might be to gain a working knowledge of a program like 'After Effects' (a steep learning curve there as well) that is a "special effects" software that is good at working in 3D space (although not as good at 'designing' 3D elements) but there are a ton of logo reveal "Templates" available that might suit your purposes and can be easily 'edited' with a somewhat basic working knowledge of the software. http://www.adobe.com/ca/products/aftereffects.htmlHope that helps some, keep us all posted as to how you make out. Ice
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
I'm a subscriber to Adobe Creative Cloud.
I've found given the time and patience Adobe After Effects can accomplish quite a lot. Maybe not quite to the level in the Youtube video.
I use it because effectively it comes with my subscription and I use Photoshop, Acrobat DC and Premier. Anyway if you have access to After Effect, it's pretty good at making logos spin and things like that. I guess I like it because I'm used to the Adobe products already and didn't need to spend years learning again something new :)
I use Titler Pro 4 with Sony Vegas Pro 13. I used Titler pro to create an animated School logo from Vector graphics I extracted using DrawPlus x8. Here is that logo...
