JoseE
#1 Posted : Wednesday, November 4, 2015 5:57:09 PM(UTC)
JoseE
I update from VMix 14 to VMix 16 and when record a long clips (about one hour) on the record appear some green frames randomly.
The record configuration and the pc are the same.
Record configuration:
Avi file with GoPro Codec
25 fps
1024 x 576 Resolution
Test Pc:
Core I7@3600
16 Gb Ddr3
Decklink Studio
Decklink Mini Recorder
Intensity Pro
With VMix 14 the recordings were ok without green frames.
Has this happened to someone?
José E.
