djevo1
#1 Posted : Tuesday, November 3, 2015 4:08:20 PM(UTC)
djevo1
ANyone have any idea on how to send a tally signal over the internet to another vmix computer or pc. I am hosting a webshow where we have multiple presenters streaming to a cdn then back into a master vmix switcher and would love to have a tally system so presenters know when their feeds are live. Each location is in a different part of the country
jhebbel
#2 Posted : Tuesday, November 3, 2015 4:21:38 PM(UTC)
jhebbel
Accessing the web control board is possible over the internet if you set up a NAT or port forwarding, if you are looking for more of a dedicated hardware software solution, the code here http://forums.vmix.com/d....aspx?g=posts&t=5402 will help set up the scraping side of it, the actual tally board depends on your implementation.
djevo1
#3 Posted : Tuesday, November 3, 2015 8:45:44 PM(UTC)
djevo1
I am mainly looking for and indictaor so our members know they are live
jhebbel
#4 Posted : Tuesday, November 3, 2015 8:52:42 PM(UTC)
jhebbel
Right, you should be able to use the web interface to suit your needs.
