geniusweb
#1 Posted : Wednesday, October 28, 2015 8:21:58 AM(UTC)
geniusweb
Hello, I would loke to ask you if it is possible to setup vmix settings (framework) to 1080p 30 fps and connect 2 cameras with different resolutions. One with 1080p 30fps and second one with 720p 30fps. Output from vmix will be 1080p 30fps.
Is this setup possible? Will the second camera resolution upscaled automatically, or all the camera sources have to match framework settings of vmix?
Thank you.
#2 Posted : Wednesday, October 28, 2015 8:50:41 AM(UTC)
@ geniusweb
Yes, it is most definitely possible, vMix scales 'everything' according to your "Output" resolution, the caveat might be your method of capture...
Not all capture cards handle all resolutions and framerates.
thanks 2 users thanked IceStream for this useful post.
doggy on 10/28/2015(UTC), geniusweb on 10/28/2015(UTC)
geniusweb
#3 Posted : Wednesday, October 28, 2015 10:57:50 AM(UTC)
geniusweb
mmm, ok but for what is then framework resolution - preset? I don't mean output resolution but one which you can setup at the beginning - preset.
#4 Posted : Wednesday, October 28, 2015 7:12:45 PM(UTC)
@ geniusweb
Are you perhaps referring to "Master Frame Rate" settings?
I'm not exactly sure what you mean by "framework resolution - preset"...
What are your current settings and have you tried to use different resolution cameras without success?
geniusweb
#5 Posted : Thursday, October 29, 2015 4:10:27 AM(UTC)
geniusweb
Yes IceStream, sorry for that, I mean master frame rate.
So Master frame rate is that settings which will be used in Fullscreen output?
If yes, can I have different master frame rate settings and different input camera settings? For example camera will have 720p 50fps but master frame rate/resolution will be 1080p 30fps?
Will this work in way that master output will be full HD and lower resolution inputs will be upscaled?
Thank you.
