Cpilcher
#1 Posted : Tuesday, October 27, 2015 9:59:56 AM(UTC)
Cpilcher
I have been looking for an answer to this and have been unable to find the answer...
1.) I have a lot of shortcuts and I am starting to utilize the web controller. Is there a way to rename the shortcuts? I would like to be able to give a more specific name for the web controller because I have a few shortcuts that look similar in their action and it is quite difficult to tell them apart.
2.) when creating Titles from within vMix, or web controller... Is there a way to organize the list of Titles other than the order they are initially created? I like to have the titles in order but often the order will change and I am having trouble finding a way to re-arrange them.
Thanks as always, I have learned so much from reading all the past forum posts. There is a great community here.
Cpilcher
#2 Posted : Tuesday, October 27, 2015 1:42:29 PM(UTC)
@ Cpilcher
1) AFAIK, NO, the 'Shortcuts' are referenced by the key being used, the chosen function and the Input. Perhaps a 'Feature Request' is in order if you think a re-naming option would be beneficial.
2) Not sure I fully understand what you are referring to by "list of Titles". Can you elaborate a little more? Individual "Inputs" can be moved around simply by 'drag and drop' if that is what you mean in terms of 're-ordering' your Inputs.
richardgatarski
#3 Posted : Tuesday, October 27, 2015 5:33:54 PM(UTC)
richardgatarski
@Cpilcher
Re 2. There is no way to re-order the list of title entries in the Title Input's title editor if that is what you mean, but you could perhaps ask for it as a Feature request.
One workaround for that would be to Export (in the Title Input's setting), reorder manually with an editor like Notepad, and then Import it back. Or do you mean to re-organize a number of Title Inputs?
Not sure what's your use case, but perhaps SmartTitler is another solution...(although not really released yet).
ask
#4 Posted : Tuesday, October 27, 2015 5:54:42 PM(UTC)
ask
To rename the shortcut in the Web Controller use the TITLE Field in the edit screen for that shortcut. To reorder, Use the Up/Down arrows to move the shortcut in the Shortcut Grid view.
IceStream on 10/27/2015(UTC)
#5 Posted : Tuesday, October 27, 2015 6:03:49 PM(UTC)
ask wrote:
To rename the shortcut in the Web Controller use the TITLE Field in the edit screen for that shortcut..
Thanks ask, I learn something new every day!
Cpilcher
#6 Posted : Tuesday, October 27, 2015 9:48:30 PM(UTC)
Cpilcher
Thanks for the responses. I have looked at smart titler and it looks promising.
I was referring to the "Presets" that are created within the Title Input window. I need to fine tune my vocabulary so you guys understand what I'm talking about. I will have to play around with these options and see how it goes.
