Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
I read the Teradek website and i find this: "Teradek encoders are also integrated with vMix. No plugin is required for automatic, low latency, high definition ingest over WiFi and from bonded connections using Teradek's Sputnik server" (link here http://teradek.com/pages/streamreader ). My question is this: what model of encoders ? all teradek encoders ? Vidiu and Vidiu Mini also supported ? Thank you
Groups:: Registered
I can confirm that the Cube works well with vMix.
I know that the cube work with Vmix but the real question it if vidiu mini work with Vmix directly on local network over Wi-Fi ;). Teradek have an IOS app ( Live to Air ) that work with this type of encoder over local network wi-fi ;)
@instudiomedia, please search the Forum, this has been discussed in other topics here.
Yes i know Wowza or Nginx server but this is not an answare it is a workaround.I like to know for sure ( maybe from vmix stuff or Martin ) if vidiu mini it is supported natively in vmix.
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
instudiomedia wrote:I like to know for sure ( maybe from vmix stuff or Martin ) if vidiu mini it is supported natively in vmix. No, it's not.
