playlist consists of inputs
I have to create a playlist consisting of camera inputs and insertion of graphics that automatically generate this sequence: Camera 1 for 3 minutes, the camera 2 for 1 minute, 5 minutes to insert graphics, video camera 3 for 7 minutes and so on.
I have to interrupt the cycle by sending a video clip in output despite the playlist is not complete.
how can I manage? thank you
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ mixsystem
Best advice is to "play" with the 'PlayList' feature and become familiar with its operation.
Essentially, the process is this: Click the cog wheel of the Playlist button Select the "Inputs" you want Double click the selected "Input" to set up the parameters such as duration and transition etc. Tick the appropriate boxes for your particular scenario And you are pretty much ready to "Start" your playlist. You can "Stop" or interrupt your Playlist manually at any time.
Hope that helps some,
perfect compiling a playlist is all ok thank you
