Saving Preset - Some Settings don't Save
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
I had a 3 day marathon webcast (11 hours each day). On a few occassions I had to shut-down vMix or reboot my laptop. When I reloaded the preset, some of the settings were reset to the default:
1. Ticker.xaml - None of the settings for Fonts or Text gets saved. It always defaults back to the latin text at a larger font than I saved.
2. Video Delay - There is a drop-down box which allows the user to select the amount of the clip to save. The default is 5 seconds, I changed this to 30 seconds before I saved the preset, but when the preset was reloaded, the drop-down box again showed 5 seconds. I didn't realize this for some time so I have many useless clips.\
Other than these 2 inconveniences, the session was perfect.
Kelvin, Glad that it worked :) And hope you had a good sleep afterwards ;) Any clips you can share? Regarding 1. See if my suggestion in another topic helps you. (I don't use video delay, so I refrain from commenting 2.).
