2 Pages12>
mixsystem
#1 Posted : Monday, October 19, 2015 12:27:24 PM(UTC)
mixsystem
how can I make a collapsed that got the text from a text file .txt. the file content changes every three minutes as I can align the contents of the file in the collapsed? thank you
#2 Posted : Monday, October 19, 2015 2:02:46 PM(UTC)
@ mixsystem
I think we may have lost something in the translation...
Can you describe differently or provide a visual aid to what it is you want to accomplish?
(I have no idea what a "collapsed" is referring to)
mixsystem
#3 Posted : Monday, October 19, 2015 5:15:26 PM(UTC)
mixsystem
I have to insert the contents of a text file overlay. the content of the file changes every 3minutes about
thanks for the answer you want to give me
#4 Posted : Monday, October 19, 2015 6:31:48 PM(UTC)
@ mixsystem
If I understand you correctly, you want to have the text content update itself 'dynamically' and automatically.
I believe there are others who are doing this to some extent via the API and some scripting but it is outside of my knowledge base so I will leave that for someone else to contribute on that front.
There are, however, some related threads that deal with dynamic changes to XAML titles and images that may help with your general task.
http://forums.vmix.com/d....aspx?g=posts&t=2183
http://forums.vmix.com/d....aspx?g=posts&t=3837
And then there is SmartTitler from Richard Gatarski:
http://forums.vmix.com/d....aspx?g=posts&t=2958
All-in-all though, you are not the first to 'request' this type of feature in vMix.
As stated, I believe it is possible, it is just not something that is easily configured with the click of a button or setting in vMix.
mixsystem
#5 Posted : Tuesday, October 20, 2015 7:11:01 AM(UTC)
mixsystem
thanks for perfect pictures I can do it, it works perfectly. but to a text file, there is no solution?
thank you
mixsystem
#6 Posted : Tuesday, October 20, 2015 7:12:35 AM(UTC)
mixsystem
in short, I would need a dynamic text
#7 Posted : Tuesday, October 20, 2015 7:15:18 AM(UTC)
@ mixsystem
see this post for example example
it checks a (xml)file every .5 sec.
instead of populating a listbox one has to populate a textfield in your title. key here is that it checks the source file at regular interval
mixsystem
#8 Posted : Tuesday, October 20, 2015 7:57:18 AM(UTC)
mixsystem
It could be a solution, but I can not create code suitable for my needs.It can help you?
thank you
#9 Posted : Tuesday, October 20, 2015 9:16:29 AM(UTC)
Like this (see attached)
load *.dll file as title
edit and save text in TestFile.txt
will check for change every 3 seconds
File Attachment(s):
testtitleupdate.zip (8kb) downloaded 20 time(s).
mixsystem
#10 Posted : Tuesday, October 20, 2015 9:39:18 AM(UTC)
mixsystem
perfect is what I was looking for. now I should change the code to read from a file with a .txt extension to a folder on your PC
thank you
#11 Posted : Tuesday, October 20, 2015 12:26:10 PM(UTC)
on my computer ??
mixsystem
#12 Posted : Tuesday, October 20, 2015 2:06:51 PM(UTC)
mixsystem
the text file containing the text you have to enter in output is in a folder locally.
example r:/regia/OnAir.txt
how can I do?
thank you
#13 Posted : Tuesday, October 20, 2015 3:54:12 PM(UTC)
here is the basic of the code (MS Visual Basic 2010 Express compiled as .dll)
xaml.vb
Code:
Imports System.Windows.Threading
Imports System.IO
Public Class UserControl1
    Private WithEvents m_Timer As New DispatcherTimer
    Private Sub UserControl1_LayoutUpdated(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.LayoutUpdated
        If m_Timer IsNot Nothing Then
            m_Timer.Interval = TimeSpan.FromMilliseconds(3000)
            m_Timer.Start()
        End If
    End Sub
    Private Sub m_Timer_Tick(ByVal sender As Object, ByVal e As System.EventArgs) Handles m_Timer.Tick
        InitializeComponent()
        Try
            Using sr As New StreamReader( "r:/regia/OnAir.txt")
                Dim line As String
                line = sr.ReadToEnd()
                TextBlock1.Text = line
            End Using
        Catch
            TextBlock1.Text = "Could not read the file"
        End Try
    End Sub
End Class
xaml
Code:
<UserControl x:Class="UserControl1"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             mc:Ignorable="d" Width="1920" Height="1080" xmlns:my="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary" Padding="5" Margin="5">
    <Grid  >
        <TextBlock Height="79" Margin="73,926,772,0" Name="TextBlock1" Text="TextBlock" VerticalAlignment="Top" Foreground="White" FontSize="56" Background="#FF145BAD" />
    </Grid>
</UserControl>
smudge1977 on 4/19/2018(UTC)
mixsystem
#14 Posted : Tuesday, October 20, 2015 4:53:16 PM(UTC)
mixsystem
thanks for the umpteenth time to answer and I are dedicating.
unfortunately I am not a programmer and I can not compile correctly what you have provided me.
can you kindly produce it?
thank you very much and sorry again for my ignorance
#15 Posted : Wednesday, October 21, 2015 12:08:18 AM(UTC)
Would be practical if you could provide me with a title example as of where on the screen ( and size etc ) you want the text to appear.
You can use the vMix title designer to do this and provide it ( or the code of it)
mixsystem
#16 Posted : Wednesday, October 21, 2015 5:25:02 AM(UTC)
mixsystem
I would like to get a result as in the link
https://drive.google.com...QTBRak0/view?usp=sharing
I got it with "Title / XAML" of Vmix named "News HD5" making changes, I removed a row and reduced in height by stretching in length
I hope we can do
thank you
#17 Posted : Wednesday, October 21, 2015 5:52:06 AM(UTC)
See attached (kept it universal)
- load as title
- right click and specify duration (of interval) in seconds and specify file location (c:/dir/yourfile.txt)
- change textcolor, size etc with the title options available
- position your appearing text / title according to your liking ( or on top of your personal background)
- long texts do not wrap but multiline is possible (hence starting top of title)
- there is NO error trapping (except if file is not found)
- Use at own risk !
File Attachment(s):
vMixReadText.zip (8kb) downloaded 26 time(s).
DYosua on 10/21/2015(UTC)
mixsystem
#18 Posted : Wednesday, October 21, 2015 10:45:42 AM(UTC)
mixsystem
perfect perfect I got the desired result.
I thank you infinitely ..... thanks again for your patience
Now I would have two questions to ask but do not think it appropriate to continue on the same topics, though I try.
1) it's configuration, I would like to know the procedure for the inclusion of the "station logo" Now I plug in "Multi View" But I have to duplicate it on each input. There is a procedure to put it on 'total output?
2) I need to create a playlist consisting of camera inputs inserting graphics and cameras change in time. despite the playlist is not over I have to stop with a clip without the preset playlist does not return output
I hope I have expressed properly.
thanks again for the answer you want to give me
#19 Posted : Wednesday, October 21, 2015 12:19:50 PM(UTC)
welcome
1) as an constant on overlay ;-)
please post these questions in a seperate topic
mixsystem
#20 Posted : Thursday, October 29, 2015 6:28:18 PM(UTC)
mixsystem
- load as title
- Use at own risk !
dynamic text works perfectly for days running without any problems, but the reopening of Vmix despite reloading the preset does not store the path where the source file fish
how can I do?
thank you
Guest (10)
2 Pages12>
