Feature Requests
Playlist ...call it a bug
Hi
would it be posible to have set IN and OUT point of a clip transfered to the playlist please ? When such points are set , the playlist does not advance to next items while it does play (the firt) according to those points
having to delete those point and instead specify a staring point and duration does not feel efficient.
suggestion , as option to either use starting/duration or set points
Thank you
@ doggy As stated in this related thread, the "Playlist" plays fine for me with new Marked IN and OUT points, perhaps a setting is out somewhere or there is a glitch in your video clip. I cannot seem to reproduce your issue. What format are your clips? Ice
They are .mp4's Reindexed them but still the same problem
tried with others (alo mp4) and those work but they had audio. did notice the cips stopped at the appropriate time but the sound continued a bit longer before the next clip started playing
Feature Requests
