Own set up like Vmix GO plus
Joined: 1/21/2014(UTC) Posts: 82 Location: sportwebtv.be
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Hi
I have a atem quad 4 sdi card and build now on the base of the Vmix GO plus version a new PC with exactly the same components:
Intel i7 4790k, Nvidia GTX 750ti 2GB, 250GB SSD system drive, 32GB DDR3 memory, 1TB Instant Replay drive, 1TB video storage, Failover Drive, Wifi
(http://www.vmix.com/images/go/vMixGO_BasePlus_SellSheet.pdf)
This new pc I use only for mixing and replay. Programm output goes to a second pc for recordording, graphic overlays and encoding (upload).
I expect that the new pc has no problems works with 4 camera inputs and 4 replays.
Can I expect that? Thanks for you opinion.
Best regards Patrick
@ tgdzapa1
Can you elaborate on your capture card? AFAIK, the ATEM does not work independently as a "capture card" outside of the BMD TV Studio software.
It may be difficult to build using the "exact same components" as they are not specifically listed (i.e. motherboard, capture card and storage drives). Certainly, the vMix Go has been thoroughly tested and will work, trying to replicate that with 'similar' components "should" work in theory, but there are some compatibility issues that have been documented so do your research and build wisely and accordingly.
