how to make vidio ratio normal in the scheduler?
hy, can you tell me how to change vidio ratio in scheduler? from source in the begining to normal to be full screen.. thanks before..
@ bunayya01
Unfortunately, AFAIK there is no setting that will change the 'Aspect Ratio' from "Source" when loading from the vMixScheduler. An alternative would be to load or add your "Event" (or "Events" if you have many) into vMix first and establish the correct aspect ratio you want and then use the "Input" selection of the scheduler to "play out" your show. This is far more intensive in terms of scheduling because you will have to manually set the duration of each "Input" you add, but it is the only way I know of to pre-determine the aspect ratio of your selection.
Hope that helps.
