Hey guys!
I wonder if you can set video delay at 15 seconds, save the delay at 15 seconds but play the delay "live feed" at five seconds? If so; how do I setup?
Joined: 5/20/2015(UTC) Posts: 493 Location: Copenhagen, Denmark Thanks: 383 times Was thanked: 100 time(s) in 79 post(s)
MegaJos wrote:Hey guys!
I wonder if you can set video delay at 15 seconds, save the delay at 15 seconds but play the delay "live feed" at five seconds? If so; how do I setup? I dont know exactly what You are trying to accomplish, however, it is possible to add a trigger in your delayed video, so when you go live with that very input, it will only stay on for 5 seconds, and then cut/fade to the preview. For your delayed input: Open Settings > Triggers > Set "OnTransitionIn" and Function to cut/fade and delay to e.g. 5000 for 5 seconds > Add. stigaard attached the following image(s): vmix_trigger_ontransition_in.PNG (14kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
stigaard wrote:I dont know exactly what You are trying to accomplish, however, it is possible to add a trigger in your delayed video, so when you go live with that very input, it will only stay on for 5 seconds, and then cut/fade to the preview.
For your delayed input: Open Settings > Triggers > Set "OnTransitionIn" and Function to cut/fade and delay to e.g. 5000 for 5 seconds > Add. The thing is that I want to replay the last five seconds of the video delay, not the first. Great tip though.
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 23 time(s) in 21 post(s)
I wonder if you can set video delay at 15 seconds, save the delay at 15 seconds but play the delay "live feed" at five seconds? If so; how do I setup? After you add the video delay, slide the marker to the 10 second mark. It will show that you are at the 10 second mark of the 15 second cache. Now when you move it to Live, it will only play the last 5 seconds. tdurhamjr attached the following image(s): 5 Second Delay.jpg (273kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
tdurhamjr wrote:After you add the video delay, slide the marker to the 10 second mark. It will show that you are at the 10 second mark of the 15 second cache. Now when you move it to Live, it will only play the last 5 seconds.
Another case of being unclear. I'm Swedish, sue me. ;) I meant by shortcut key. That makes producing simpler.
