legrand62
#1 Posted : Wednesday, September 30, 2015 4:39:55 PM(UTC)
legrand62
Hello
To ease my usage of vmix and of replays, I'm trying to implement a script through the scripting feature.
First
Function=ReplayMarkInOutLive&Value=5
Allow me to create a replay of the last 5 seconds
Then I'm looking for a way to load the last replay in my preview
Finally
Function=Stinger1
Allow me to trigger my stinger
Could you please help me ? I do not find the right function(s) to use to do what I expect.
Olivier
legrand62
#2 Posted : Friday, October 2, 2015 4:15:27 AM(UTC)
legrand62
Any idea ?
I'm looking for the function which will allow me, through the scriting feature, to load the last replay I've done in my preview.
Thanks for your suggestion and your help.
Olivier
#3 Posted : Friday, October 2, 2015 8:43:04 AM(UTC)
@ legrand62
I am not familiar with 'scripting' or the scripting feature but my understanding is that it is built around the 'Shortcut' functions, in which case you probably require a couple of different steps (if my memory serves me correct on how the "Replay" feature works):
1) to select the last replay event ('ReplayPlayLastEvent' which should select and play the replay in the designated replay window).
2) you may have to pause the playhead ('ReplayPlayPause').
3) to select appropriate target [A or B] to 'Preview' ('PreviewInput' and choose input).
It's been a while since I have 'played' with the "Replay" and it's features, so there may be a more direct way to do this, but based on your description of sending the 'Replay' to the 'Preview' screen, that would be how I would approach it through 'Shortcuts'.
I hope that is somewhat helpful.
