Hardware Compatibility
Logitech c930e with greenscreen
Hey, I am looking for a new camera, because my old has a really bad resolution. I think about the lg c930e, do anybody have experience with it and the greenscreen function at vMix? If yes, do you recomend the cam or something else?
I would like to send with the highest possible resolution of 1920 x 1080 Pixel:)
Sry, for english
Thanks Phill
I got one a couple weeks back, and it has much better color quality than the c920 does, just as the c920 was that much better quality cam than the c270 is.
I don't do green screen though, so can't answer that, but I would think it would be as good or better than the c920.
I ask because there were some discussions that the c930e doesn't work with vmix with the resolution of 1920 x 1080 Pixel and 30 Frames.
 1 user thanked bluelagune for this useful post.
I'll verify when I can, but I'm sure it is configured as such.
