kjones9999
#1 Posted : Sunday, September 20, 2015 6:16:36 PM(UTC)
kjones9999
Hi folks.
What I am attempting to do is find a way to tweet the scoreboard values(text fields and Score) somewhat automatically.
I was able to take the status results from 127.0.0.1:8088/api and pull out the needed info using XSLT by copying and pasting the api status values and running the XSLT on the text. But it seems that without a proper xml filename, that using the xml externally will not work. There must be an actual "XML" file like data.xml. Does that exist in Vmix? Like 127.0.0.1:8088/api/status.xml?
Can anyone think of a better way to get the data from the scoreboards? Any suggestions on this journey is welcome!
kjones9999
#2 Posted : Friday, September 25, 2015 11:58:24 PM(UTC)
kjones9999
I gave up on a text based solution because I found a way that I like much better.
Using a program called sharex, I tell sharex to tweet a screen capture of the scoreboard every 10 minutes or so. I don't have to do anything, it happens in the background...
https://twitter.com/wzco...7257139497537536/photo/1
sinc747
#3 Posted : Saturday, September 26, 2015 1:22:58 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Very cool. Thanks for sharing!
ask
#4 Posted : Saturday, September 26, 2015 4:33:02 AM(UTC)
ask
This has all sorts of possibilities! Many thanks....:-)
