I've search the forum but didn't come up with an answer. Is there a way to output to an external video monitor, not a computer monitor?
Thanks,
BobR
@ BobR
You have to output through an I/O device, typically a Video Capture card that has the ability to either Input or Output. [example: an Intensity Pro] Select that device in 'External Output' in "Settings".
Alternatively, if your graphics card has dual monitor capabilities, you could 'send' the "Fullscreen" output signal to your video monitor (although additional conversion/connections may be required).
