#1 Posted : Friday, September 4, 2015 8:57:28 AM(UTC)
16.0.0.67
* Fixed bug where Input dropdown box was hidden for shortcut function SetOutputFullscreen
* SetOutputFullscreen will now accept input names through API
* Enabled analog output support for compatible AJA devices (Kona 3G, Kona 4, Kona LHi etc)
richardgatarski on 9/4/2015(UTC), PFBM on 10/1/2015(UTC)
#2 Posted : Friday, September 4, 2015 11:53:27 AM(UTC)
16.0.0.68
* Fixed bug when finding Twitch servers
#3 Posted : Wednesday, September 9, 2015 11:04:53 AM(UTC)
16.0.0.71
* Removed past duration error message from FFMPEG streaming logs
It was being caused by slight (less than 1 frame) timing differences between vMix and FFMPEG and
can be safely ignored.
* Added StreamSpot to streaming destinations
* Added support for additional X-Keys devices (in particular X-Keys 60)
* Using API to select Input by name will now match either the full title as displayed in vMix
or the custom title in Input Settings
* Fixed frame rate matching bug in Instant Replay with some 59.94/60p sources
* Fixed QuickPlay function now showing Input dropdown box
* Fixed aspect ratio bug when loading Desktop Capture from Preset
thanks 5 users thanked admin for this useful post.
Len56 on 9/9/2015(UTC), sscs on 9/9/2015(UTC), madness on 9/9/2015(UTC), ClementN on 9/10/2015(UTC), PFBM on 10/1/2015(UTC)
#4 Posted : Thursday, September 17, 2015 10:20:02 AM(UTC)
16.0.0.73
* Fixed bug where wrong information was being displayed in Streaming URL and Stream Key
when switching between profiles while [2] or [3] are selected.
* Fixed replay bug where clicking Remove in right click menu would remove event even if No was selected.
* Added support for ProRes videos with alpha channel. May need to toggle Premultiplied Alpha
setting in Input Settings depending on how video was rendered.
* Added more error handling for systems where a broken audio device in the system results
in the Add Input -> Audio Input dropdown box to be blank.
* During install, vMix Social icon would be created even if it was removed by the user.
Now it will only be created the first time vMix is installed.
madness on 9/17/2015(UTC), PFBM on 10/1/2015(UTC)
#5 Posted : Sunday, September 20, 2015 11:40:02 AM(UTC)
16.0.0.75
* Fixed issue where Create Virtual Input would copy shortcut mappings, breaking existing shortcuts.
* Fixed some audio effects resetting when moving between videos in a List
* Removed VC-3 bitrates not supported by FFMPEG
#6 Posted : Thursday, September 24, 2015 8:20:28 AM(UTC)
16.0.0.78
* Fixed bug with FFMPEG recording when starting streaming after.
* Improved low latency when using "Low Latency Capture" mode.
* Create Virtual Input menu moved to Cog menu instead. Menu to be expanded in the future.
madness on 9/29/2015(UTC), PFBM on 10/1/2015(UTC)
#7 Posted : Monday, September 28, 2015 11:38:19 AM(UTC)
16.0.0.86
* Improved performance and lower latency with AJA devices
* Support for AJA Io XT added
* Fixed problem with vMix Update closing itself during an update.
* Audio Input and Outputs now have "Device Volume" control in Audio Settings
This controls the underlying volume control of the hardware if available.
(Useful if audio level is too high prior to being received by vMix)
* Fixed a couple of audio issues on vMix GO systems and improved quality.
* vMix GO audio I/O device names changed to make them easier to recognise.
* Fixed issue loading Elgato devices from a Preset
* Added "Access-Control-Allow-Origin: *" to Web Controller headers
#8 Posted : Monday, September 28, 2015 10:40:46 PM(UTC)
16.0.0.87
* Fixed bug with last frame in Video Delay saves
* Updated vMix Update to provide warning applications may be closed
* vMix Video Indexer application included which will quickly index any videos that were recorded
in MP4 or MOV without indexing.
thanks 3 users thanked admin for this useful post.
sinc747 on 9/28/2015(UTC), madness on 9/29/2015(UTC), PFBM on 10/1/2015(UTC)
#9 Posted : Thursday, October 1, 2015 10:15:29 AM(UTC)
16.0.0.92
* NEW Hardware Encoding support for Streaming (Beta)
Check the tickbox in the Streaming Settings window to try it.
It supports NVENC, which means most recent NVIDIA cards should work (7xx,8xx,9xx series and some high end 6xx series as well)
* Improved FFMPEG recording performance across the board due to a couple of bug fixes.
Should see lower CPU and memory usage.
* Added MIDI template for the AKAI APC40 MK2 controller
The AKAI controllers are particularly nice in that they include a T-Bar like A-B control.
* Fixed bug where Shortcuts Advanced Triggers do not activate when buttons pressed in Web Controller or via MIDI.
* Made sure Stinger transitions will always start from the beginning regardless of "Restart with transition" setting.
* vMix Video Indexer renamed to vMix Video Tools and can now be used to create Image Sequences out of video files as well.
PFBM on 10/1/2015(UTC), madness on 10/1/2015(UTC), GeorgeR on 10/9/2015(UTC)
#10 Posted: : Saturday, November 7, 2015 5:58:30 PM(UTC)
16.0.0.104
* Performance improvement and reduction in render time when displaying more than 8 inputs on screen at the same time.
* Two new Chroma Key anti aliasing options added. (Medium and High) (Need at least NVIDIA 950 or higher for best results)
* Updated FFMPEG to latest version for improved video format playback support.
* vMix Control Surface bug fixes
* Fixed audio mixer position not being saved in some situations
* vMix installer now automatically updates the AJA drivers if they are out of date
* Fixed problem with stingers when using some MOV files (did not restart correctly)
* Fixed bug with vMix Social not connecting on some systems
* Fixed issue where List may not end or restart when some items at the end of the list are unchecked.
* Virtual Set Visible button state is now saved in presets.
thanks 4 users thanked admin for this useful post.
kgoodyer on 11/8/2015(UTC), ClementN on 11/8/2015(UTC), GeorgeR on 11/8/2015(UTC), madness on 11/10/2015(UTC)
#11 Posted : Friday, November 13, 2015 1:04:03 AM(UTC)
16.0.0.106
* Fixed bug where replay position label pauses when cameras angles other than 1 are selected.
madness on 11/13/2015(UTC)
#12 Posted : Tuesday, December 15, 2015 4:27:35 AM(UTC)
16.0.0.111
* Fixed issue with some M-Audio ASIO devices not working
* Fixed bug where Medium or High Chroma Key anti-aliasing was preventing fade transitions from working
* Added support for new Yuan cards
* Fixed bug where overlay transitions were restarting videos even if automatically restart was not checked
madness on 12/15/2015(UTC)
#13 Posted : Wednesday, December 23, 2015 9:42:23 AM(UTC)
16.0.0.112
* VFTLS bug fix: Improved reliability of vMix Control Surface when plugged into USB 3.0 port and hubs
#14 Posted : Wednesday, January 6, 2016 12:43:08 PM(UTC)
16.0.0.114
* Removed "FlipEx" performance mode for input previews.
Compared to previous versions, it reduced render times, especially when using 50p frame rates and higher.
Unfortunately it can also cause the Windows Desktop Window Manager to use large amounts of CPU and lock up temporarily when scrolling
the inputs window, so it has been disabled until a better solution can be found for vMix 17.
madness on 1/6/2016(UTC)
#15 Posted : Friday, January 22, 2016 9:05:08 AM(UTC)
16.0.0.115
* Fixed compatibility bug with latest Firmata firmware and Arduino Tally Lights.
* Fixed Input.Preview and Input.Output not working correctly in Scripting
Guest (11)
