Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi there
I’m just wondering if anyone has used a bonded router to allow for a reliable internet connection? At the moment I’m just relying on venue internet wherever I go but it does make it a bit nervous. It would be great to have a router that can bond together 3G/4G/LTE/WIFI/Ethernet connections to make it really reliable.
Does anyone have any cost effective solutions? I was looking at the LiveU type systems but they are expensive and I don’t really need the encoder side of things as I’m just using the VMix encoder.
Any thoughts?
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
There are a number of hardware solutions that are quite pricey like the Terradek Bond. On the software side look at speedify.com I have used it for the last few months with success. Reasonable price.
ask wrote:There are a number of hardware solutions that are quite pricey like the Terradek Bond. On the software side look at speedify.com I have used it for the last few months with success. Reasonable price. Nice! Thanks for that... Speedify looks great. I'll give it a try here in Australia... does the connection rely on the Speedify servers at all? Cheers
