vmixnewbie
#1 Posted : Sunday, September 13, 2015 6:18:12 PM(UTC)
vmixnewbie
I have the latest vMix software and am trying to add 2 cameras to record our podcast for video (this won't be live). I have a new iPod Touch along with the built in camera on an Android LG-G2 phone that we're trying to add as video inputs to vMix.
So I have a few questions (in order to prevent spending thousands on a camera card)
1. Do I need to buy one or two EZcap devices (are they good?)
2. Or do I need to buy the Blackmagic Intensity product?
3. Or is an IP camera the way to go? I hear there is a delay in that.
Basically my question is how do I add 2 camera inputs (one Android, one Apple) into the vMix for as cheaply as possible?
From reading previous forum threads on here I've gathered a few links which I'll add in here in case it helps anybody else.
http://www.forums.vmix.c...t.aspx?g=posts&t=616
https://www.blackmagicde...n.com/products/intensity
http://www.amazon.com/EZ...-Supports/dp/B003YGJLWU/
http://www.honestech.com...vhs-to-dvd-80-deluxe.asp
Speegs
#2 Posted : Sunday, September 13, 2015 9:08:53 PM(UTC)
Speegs
Trying to use a phone and an iPod you need to skip all capture cards and look for an app. (nothing wrong with the capture cards, but they are not going to help much unless your source device is a video camera). Unless you are trying to screen dump the iPod/Phone via HDMI for that a capture device would be used.
From what I gather the latency is not any issue since what you are doing is not live.
Sorry I have not bought or tried any of the apps available, but at least you know what you need to look for by reading further. You can add the IP Camera as a source for Vmix.
So a phone or iPod can be an encoder (with the right APP) up to a basic resolution. At some point the device like an iPod for instance will just run out of CPU, it might be very quickly depending on the model.
Personally I don't do any work where I would accept the quality from an iPod or Phone. I imagine the software encoders on the mobile device would not be suitable for anything but very short productions.
You would better better going with an IP Camera or just a HandyCam that outputs to HDMI at least and getting a capture device long term. Magewell, Yuan and Black Magic all make suitable capture devices, have a look at the VMix Hardware Compatibility list, it really helps to research that list.
VMix help file shows these formats are supported in Version 16. Searching for "encoder" in the Apple/Google Store might point you towards the end result. I can't recommend any, so try free ones first.
Stream Type
RTSP over UDP / RTSP over TCP
RTSP based sources such as the Teradek Cube and IP Cameras
Enter the URL in the following format: rtsp://0.0.0.0/stream1
Transport Stream over UDP
Select this option if a Transport Stream is being sent directly to the vMix machine over UDP
Transport Stream over TCP
Selecting this option sets up vMix as a TCP server that can accept connections from remote streams
Enter the port to listen for connections
Transport Stream over TCP Pull
Select this option to connect to a remote Transport Stream server such as the Teradek Sputnik using the TCP protocol.
Enter the hostname and port of the remote Transport Stream server
So I'm not able to directly answer your questions, but maybe point you into directions to help yourself.
Final thought, why not look at a Webcam (or two)? Latency is not bad on them. They don't need a capture card, look pretty good if you buy a good one + get the lighting right and are really cheap. Some of the higher end Logitech ones are popular.
Speegs
#3 Posted : Sunday, September 13, 2015 9:16:26 PM(UTC)
Speegs
If interested in Webcam option.
Watch this video:
?t=12m50s
Shows the Logitech C920, but there are hundreds of choices. This video goes into how to add a 4 port USB card and 4 USB Cameras. You will not need that, if you already have 2 functioning USB 3 ports you will have what you need.
#4 Posted : Monday, September 14, 2015 12:00:47 AM(UTC)
@ vmixnewbie
Speegs is right. Although, you are definitely not the first to want to do this, you've probably even thought "this is a no brainer".
Unfortunately, those devices are not designed to be "cameras" of that nature, they don't have a typical 'output' jack that can be used to transmit a video signal to a capture device and be used as an input in vMix.
It will require additional software or Apps to be used and often the quality is nowhere near the quality of the actual camera on those devices, but it can be done.
The most straight forward example of how it can be done, and to some extent illustrate the complexity of it all, would be setting a device up as Skype call into vMix (again additional software involved, but certainly do-able if you are up to the challenge).
I think the webcam suggestion is the simplest and will get you up and running in no time. Fiddling around with how to get your iPod camera to be a source might prove to be more trouble than it's worth.
Just my thoughts.
vmixnewbie
#5 Posted : Monday, September 14, 2015 2:19:16 AM(UTC)
vmixnewbie
Thanks all for your insights.
I recorded this (sometimes easier than typing): http://vocaroo.com/i/s0Iu3UU8ylb7
So it looks like the two cameras I have (iPod Touch and the Android LG-G2) are probably not the best to use for this setup. I have a logitech webcam c920 that I was able to input into vMix with zero problems.
Should I get another camera like that and put it on a tripod to film my co-host to make a show?
I'd rather not do that if I can help it because it does seem to have some latency and delay issues. The quality doesn't seem all that good.
If I were to go another route and purchase 2 cameras that are cheap but good quality what should I get and how would I input them? Would the USB option be best in this case?
#6 Posted : Monday, September 14, 2015 11:56:52 AM(UTC)
@ vmixnewbie
Rather cool to hear you on 'Vocaroo', I've never seen that method used on a forum before (maybe I'll try that sometime, you may be starting a trend...)
In terms of 'latency', computer processing of digital video is inherently latent, the question of how much is dependent largely on your system specs.
Some high end units using high end components and capture cards are known to get the latency down to a frame or two, but typically you should expect somewhere between 100ms and 300ms on most average systems, which is enough to be noticed by the human eye but usually acceptable enough to pass for 'Live' (that's about a quarter of a second). If you are noticing greater latency than that with a web cam, then you may have to look more closely at your system's capabilities and what might possibly be causing a bottleneck.
If latency of any kind is unacceptable to you, then you may have to look into much more expensive 'hardware' solutions because the reality is that there will always be 'latency' of some sort with computer processing (it's getting better all the time, but then again, so is the image quality we are processing SD to HD to 4K).
My best advice is to TEST and experiment as much as possible with what you've got or can easily acquire before jumping in too deep with expensive options, you may be pleasantly surprised with what is presently possible for you right now.
vmixnewbie
#7 Posted : Monday, September 14, 2015 12:07:09 PM(UTC)
vmixnewbie
@IceStream
I know right? Sometimes it's easier than typing for me! I created a new one with some more questions about a Go Pro camera and how many EZ Captures I'd need to buy for what I wanna do.
Thanks for helping me out!
http://vocaroo.com/i/s0p6koaJwV79
#8 Posted : Monday, September 14, 2015 2:34:16 PM(UTC)
@ vmixnewbie
To be honest, I am not all that familiar with the GoPro cameras and their video output.
AFAIK, older models do not output a 'live' video feed (but I could be wrong about that).
Newer models are supposed to output via HDMI which means you will need a capture device or dongle to accommodate that.
Other issues seem to plague users with getting the proper settings across the board in order to capture it properly in vMix.
Again, I don't want to come across as 'knowledgeable' with regards to GoPros, because I have absolutely no experience with them.
I've seen some great footage from them, but always as recorded in cam and edited in post, I am not as aware of it's use as a 'Live' camera, but there are others here that have and are using them so perhaps a search through the forum might shed some light on things.
desmar
#9 Posted : Monday, September 14, 2015 3:30:26 PM(UTC)
desmar
Canada
@vmixnewbie
use airserver, it will do what you need.
http://www.airserver.com/
Steps
Option 1 using same PC running Vmix and Airserver
1) Install and run airserver
2) Connect with IOS (ariplay) , Android (screen mirroing), Windows device to airserver
3) Select view in full screen for Airserver once devices are connected
4) Alt + Tab to bring back to vmix program
5) Add input
6) Select Desktop Capture
7) Select Airserver Universal
8) Check off Capture hidden window.
9) Click ok
You will notice Airserver doesn't have a different window for each device,
it will be in the same window side by side.
10) Right click on desktop capture input with airserver displaying your devices and select create virtual input.
11) Repeat step 10
12) goto settings for each new virutal input to adjust cropping and resizing of window for each devices.
Option 2 Best option
1) Install Desktop Capture on 2nd PC to send desktop capture to Vmix.
2) Install and run Airserver on 2 PC's
3) Connect with IOS (ariplay) , Android (screen mirroing), Windows device to airserver
4) Select view in full screen for Airserver once device are connected
on 2nd pc
5) Must stay on full screen with airserver
on pc running Vmix
6) Alt + Tab to bring back to vmix program
7) Add input
8) Select vmix pc running airserver
9) Select Desktop Capture
10) Select Airserver Universal
11) Check off Capture hidden window. on Vmix pc only
12) Add input
13) Select 2nd pc running airserver
14) Select Desktop Capture
15) Select Airserver Universal
16) Click ok
Enjoy....
desmar attached the following image(s):
Speegs
#10 Posted : Tuesday, September 15, 2015 12:08:35 AM(UTC)
Speegs
Good move giving up on the iPod + Phone as video sources. Not impossible but way hard and the end result will be not very nice anyway and full of limitations.
I'm a huge fan on Magewell Capture Devices so far. This is the model to get: http://www.magewell.com/usb-capture-hdmi
They work with GoPro 2, 3, 4 for me. I don't have an older GoPro 1.
They have a video scaler inbuilt and don't need drivers (because they work using a universal webcam driver). That is why they awesome because you are busy/lazy and you just want something that works right away with just about any HDMI Camera. They are also pretty low latency. 1-2 frames, it will depend on how good your computer is for the most part. A quad core cpu, SSD and average video card should give you the ability to handle 3+ cameras. Magewell do some (not all) of the work in their capture box, whereas I webcam will load up your CPU more generally speaking. (Others Brands recently put out similar products like Yuan, I have not tried them so dare not recommend anything other than Magewell).
You can mess around for hours getting a GoPro working with a Black Magic capture device. Been there done that, yes can be done. The scaler makes it pretty easy, because no matter what you plug in as long as it's not 4K, the Magewell will conform it to what you want. So you don't have to think about frame rates and all that video tech stuff (although you can it has all the power as well in the advanced menus).
I like JVC Handy Cams, they are cheap (if I break it, I can get another quickly from a local electronics chain store). Sony's and others are also fine I have used them too. GoPros are good if you want that wide fish eye perspective, like a crowd shot, basketball hoop etc... Not sure you would use them in a studio EVER, but hey you could.
Anyway Magewell USB Capture ~$300 might be more, I have had mine for a while. A Full HD Handycam is much the same price. Some better than others.
That is what I often use, because I work on a very portable solution using a laptop for most of my work. USB 3 is important and avoid a USB 3 hub. Direct ports, if you are on a desktop good usb 3 cards are easy. Laptops well that's complex.
Now if your webcam is really slow, I think you may need to take a serious look at the webcam driver (from Logitech), not an expert on that, but others have reported that too on this forum. I don't use webcams myself except for Skype and Google Hangouts from time to time.
Maybe post the specifications of your computer (it might impact the advice given).
The question is can your afford 2 x USB 3 Magewell Captures Devices and 2 x HandyCams? I understand not everyone can, they are essentially the next step up from Webcams. Then it's just a matter of better than better cameras for more money and if you need very long cable runs to your cameras SDI is your friend. Otherwise SDI is expensive.
Avoid wireless if you can when starting out and also IP Cameras too. They can work very well, but the technical know how has to increase with those and usually so does the budget to do it well.
Vmix + Magewell USB 3 + Handycams + Gopros = Well Tested, Simple, Affordable, Reliable
(Not going to win a Film Award or IT but watchable)
What's your time worth? What if you could pretty much just plug stuff in and it worked right away? Then spend that time on mastering Vmix & learning your cameras vs thinking about frame rates, IP Addresses and driver configurations.
Oh and the Handycams often has 10-20x Optical Zoom, Simple Controls.
GoPro + Wifi = LowRes Preview Quality video only so avoid that.
I get no commission from anyone for this free advice :) I'm very focused on affordable solutions (but not always the cheapest, more what's value for money). People will have many solutions that might fit your situation so read this forum it's got a lot of information and research everything.
Speegs
#11 Posted : Tuesday, September 15, 2015 12:24:56 AM(UTC)
Speegs
desmar wrote:
@vmixnewbie
Enjoy....
An Wifi Screen Send and Double capture solution. Relies on 3 bits of software working together before it even gets inside VMix.
Creative, free, but maybe not the most reliable design. Mind you using mobile devices as cameras isn't my idea of reliable.
#12 Posted : Tuesday, September 15, 2015 4:15:06 AM(UTC)
Or get rid of the fisheye effect using a virtualset with adjusted UVmap :-)
see post
doggy attached the following image(s):
