Speegs
#1 Posted : Friday, September 4, 2015 5:03:33 AM(UTC)
Speegs
I just saw this Yuan EB5A0N4 on the hardware compatibility list and VMix Blog. I wanting to hear from someone who has one, so many questions.
1. How much is it? (In Australia even better)
2. Does it have an inbuilt scaler?
3. Are there any special requirements on the USB 3 port? (Magewell stuff works great on my systems, but dumping 4 inputs down the one port wow.. how does that work, is there enough bandwidth?)
4. Does it require drivers or does it work driverless and emulate a webcam?
5. Anyone have any negative/positive feedback about it?
6. Is it reliable?
Speegs
jmcmniku
#2 Posted : Friday, September 4, 2015 5:46:39 PM(UTC)
jmcmniku
here is response,to some of the questions, from our friends at Yuan :
1. Does it have an inbuilt scaler like Magewell devices?
CORRECTION: "UB5A0 no scaler inside.
They need decode h264 stream and scale the raw data by their software."
2. Are there any special requirements on the USB 3 port?
As its the hardware compression box therefore there wont be an issue for it
3. Does it require drivers or does it work driverless like Magewell?
Yes, it requires a driver. Same as our capture card series.
Speegs
#3 Posted : Friday, September 4, 2015 6:55:37 PM(UTC)
Speegs
Yes. It has an inbuild scaler on it.
I'm not quite sure what the impact of being a hardware compression box is? What would be the delay from a camera to being able to render onscreen in Vmix? Any higher than a normal capture device?
Main thing I'm thinking is DANGER.. Will not be so good for live production as would definitely have higher latency. Much like using an IP Camera as an input does (it is compressed H.264 requiring decoding via VMix). While still looks pretty good, is not a "true" image from the camera.
I'm trying to sort out the details.
#4 Posted : Friday, September 4, 2015 10:25:42 PM(UTC)
The delay is only a couple of frames when using our new "H264 Low Latency" Video Format option when adding the camera in vMix 16.
This was especially designed for devices like this and allows multiple video inputs from a single USB 3.0 device.
Speegs
#5 Posted : Saturday, September 5, 2015 4:26:53 AM(UTC)
Speegs
Sounds like an impressive unit and I'm running out of reasons not to try one. I wish it was available years ago, my systems would have be designed a very different way.
Is there a quality loss using the H264 Low Latency video format? I'm wondering what kind of H.264 bandwidth is being used down the USB 3.
If it's 20mbit + of H264 the loss will be very hard to notice. Seems this is a new way of doing things and could be great driving the costs down for capturing many cameras at once. With nice SDI connections as well.
richardgatarski
#6 Posted : Saturday, September 5, 2015 5:29:28 AM(UTC)
richardgatarski
JMC Systems in Sweden are kind to lend me one next week to try. Will report here as soon as I have played with it.
Speegs
#7 Posted : Sunday, September 13, 2015 9:25:16 PM(UTC)
Speegs
How did you go Richard?
richardgatarski
#8 Posted : Tuesday, September 15, 2015 10:58:35 AM(UTC)
richardgatarski
We did some quick test last Friday, generally OK. But I have promised to let Yuan and their distributor JMC comment before I post the report (including videos). Still waiting for their response...
richardgatarski
#9 Posted : Thursday, September 17, 2015 10:45:28 AM(UTC)
richardgatarski
OK, here you have our Unboxing and testing the Yuan UB5A04N hybrid. Full lab report there, with videos and comments from Yuan and Martin.
Quick summary: The Yuan box is really interesting, works better than we expected. On the one hand, it’s H264 compression affects the video quality. On the other hand it’s a neat way to get 4 SDI inputs (or other combos) via USB3. Main limitation is that it might require a lot of CPU power for decoding. So, if you are thinking of a portable laptop-based solution, this box may not be the solution. (Martin says he might in the future look into better CPU usage for the decoding).
thanks 3 users thanked richardgatarski for this useful post.
jmcmniku on 9/17/2015(UTC), ClementN on 9/17/2015(UTC), Speegs on 9/17/2015(UTC)
Speegs
#10 Posted : Thursday, September 17, 2015 7:21:50 PM(UTC)
Speegs
The unrecognized RS485 is essential a 2 wire + ground serial port. Great for controlling PTZ Cameras with pretty common cable.
It's common in security cameras. I use RS485 to control a PTZ via a 3 axis Joystick. Works really well. You can of course buy software to run on the computer to send signals down RS485 for camera control.
Speegs
#11 Posted : Thursday, September 17, 2015 7:31:45 PM(UTC)
Speegs
Excellent testing. I really like how you showed the cpu usage impact and you compared it to a capture device I use often :)
I like the look of what it can do. However the cpu drain could be a deal breaker for laptop use. Laptop computers don't usually have massive GPU options either so seems better suited to a desktop as you advise. Better CPUs and GPUs in laptops would help of course.
richardgatarski
#12 Posted : Tuesday, September 22, 2015 7:00:56 AM(UTC)
richardgatarski
Thanks Speegs,
And you are spot on regarding the RS485 port - Yuan also pointed this out after seeing our blog post.
hubert17
#13 Posted : Wednesday, September 28, 2016 1:10:27 PM(UTC)
hubert17
Hi Martin and Richard!
Do you have any update on this product? How is now the CPU issue?
I am planning to buy this when I visit Taiwan.
richardgatarski
#14 Posted : Friday, September 30, 2016 3:50:24 AM(UTC)
richardgatarski
No update really. We never tried the low-latency option. The high CPU usage was for us a limiting factor.
gt351
#15 Posted : Wednesday, November 23, 2016 7:30:37 PM(UTC)
gt351
any updates or known cpu usage when streaming with 4 cameras
mkobzar
#16 Posted : Wednesday, January 11, 2017 10:45:26 AM(UTC)
mkobzar
1st russian review and test yuan hardware
mkobzar
#17 Posted : Sunday, January 22, 2017 1:09:16 AM(UTC)
mkobzar
2nd video in depth about this card.
Russian language, but google works on subtitles!
ask
#18 Posted : Sunday, January 22, 2017 1:51:06 AM(UTC)
ask
Yes Subtitles work...in Russian. LOL. The production looks great however.
mkobzar
#19 Posted : Monday, February 6, 2017 4:58:05 AM(UTC)
mkobzar
Thanks, use auto translator, please.
ask
#20 Posted : Monday, February 6, 2017 4:37:59 PM(UTC)
ask
LOL. Did not realise YT did that! Not easy finding the settings, and I guess they have a long way to go with the translations...."she came out of the box four years ago"....but it made my day!
Guest (10)
