Feature request - Transparency and resizing of audio mixer window
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
We like to achieve this: Monitor the audio using the Audio Mixer Window.
In order to have a permanent monitor we like to put that window on the second monitor but in a way that will not cover the main stream coming from the Program.
So, what about having an option to make that window transparent and show only the level indicators and/or having the ability to resize that window and make it a little bit smaller?
Thank you very much,
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
The Audio Mixer will be moved to an adjustable panel in the main window from the next release. It will allow you to see both the mixer and inputs at the same time easily.
Martin vMix
That's good news.
Thank you!
