Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
Hello. Is there a way to make the automatic fade of two cameras . thank you
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ STADIORADIO
Can you elaborate or clarify as to exactly what it is you want to do?
IceStream wrote:@ STADIORADIO
Ice I would like to broadcast live what is happening inside of radio . I would like to connect two cameras in different positions, and to show , for example , a camera 30 seconds , and 30 seconds the other , without leaving a director to change from one camera to another
@ STADIORADIO
I would use the "PlayList" feature. (PlayList button along bottom of GUI) Create a new 'PlayList' Add the 'Inputs' you want Double click each 'Input' selection to set up duration, transition etc. Check the "Loop" box (and any other options you want) Push "Start" or close out and push "PlayList" button when ready to start automatic switching.
I would use the "PlayList" feature. (PlayList button along bottom of GUI) Create a new 'PlayList' Add the 'Inputs' you want Double click each 'Input' to set up duration, transition etc. Check the "Loop" box (and any other options you want) Push "Start" or close out and push "PlayList" button when ready to start automatic switching.
You are great! Thank you!
Automatic fade out?
(GT)
by Travis
8/8/2019 12:15:13 PM(UTC)
