#1 Posted : Monday, September 7, 2015 4:29:30 PM(UTC)
I was having an issue when using a "Photos" input as an overlay in a 'MultiView' special effect, on transition IN, the selection would revert back to the 1st image in the folder regardless of the 'SlideShow' settings.
Had to close the input and add a new "Photos" input with the same folder and set everything up again to fix/cure the 'oddity'.
Not sure if this is related to Windows 10 upgrade, but seems to be another one of those 'annoyances' that I never had before the switch from Win 7.
Hopefully, it is just a minor glitch that won't re-occur, but it can be frustrating when trying to figure these annoyances out thinking it might be a setting you missed somewhere.
#2 Posted : Tuesday, September 8, 2015 3:16:35 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Most likely automatically restart was enabled for the input.
#3 Posted : Tuesday, September 8, 2015 9:36:57 AM(UTC)
Actually, NO, that's what was odd...
I searched through all the settings of each input and even tried different settings, but it just wanted to do its own thing no matter what I did.
Thinking it might be a 'bug' I tried to recreate the issue with another "Photos" input, but all was normal, so I simply 'killed' my frustrations and closed the troubled input and started afresh.
