Slaver
#1 Posted : Friday, September 4, 2015 5:23:30 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
i always used the "Quickplay"-Function for my shortcuts in vMix to play Videos real quick. For example short commercial before basketball games.
In the new version its not possible anymore. You can find the "Quickplay"-Function but you cannot bind it to a media.
So is this a bug or does it happen on purpose now?
Thank you guys!
ask
#2 Posted : Friday, September 4, 2015 5:56:50 PM(UTC)
ask
Confirmed. When adding the shortcut and selecting Quickplay the input selection dropdown is missing. OK on other functions. Also quickplay seems to be linked to a fade not a cut transition.
Slaver
#3 Posted : Saturday, September 5, 2015 3:29:00 AM(UTC)
Slaver
Hope the Admins can tell us something?
I like the fade transition from the "Quickplay"-Function. Thats one of the main reasons i am using it a lot. And like i said, the possibility to bring the media in directly.
#4 Posted : Saturday, September 5, 2015 3:43:10 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
You don't need to use QuickPlay, simple select the transition effect you would like to use under the Shortcuts Function Transition
category and then set a duration. Then you can assign this to a particular input.
Slaver
#5 Posted : Saturday, September 5, 2015 8:53:23 AM(UTC)
Slaver
Thank you for the answer Martin. Just wondering why you guys changed the possibility.
I need to change it in all my 12 Installations now ;-)
#6 Posted : Saturday, September 5, 2015 10:56:22 AM(UTC)
Well to be specific, I was pointing out a more flexible alternative but you are correct that it is a bug that will be fixed in the next update.
