MatthewEarley
#1 Posted : Thursday, September 3, 2015 1:35:04 PM(UTC)
MatthewEarley
Using vMix 15 in the default settings for the AVI recording format, I found that YouTube rejected my video upload with the following error "The Video Has Failed To Process. Please Make Sure You Are Uploading A Supported File Type."
What format do you recommend for compatibility and a great looking video at 1080p on YouTube?
Ittaidv
#2 Posted : Thursday, September 3, 2015 2:18:18 PM(UTC)
Ittaidv
There are some guidelines by Youtube, they are pretty good:
https://support.google.c...ube/answer/1722171?hl=en
thanks 1 user thanked Ittaidv for this useful post.
MatthewEarley on 9/3/2015(UTC)
MatthewEarley
#3 Posted : Thursday, September 3, 2015 2:50:51 PM(UTC)
MatthewEarley
Cool and thank you - that is a useful link that YouTube did not lead me to, they lead me to a more generic version.
Newbie question:
Can I setup vMix to output the following:
Container: MP4
No Edit Lists (or the video might not get processed correctly)
moov atom at the front of the file (Fast Start)
Audio codec: AAC-LC
Channels: Stereo or Stereo + 5.1
Sample rate 96khz or 48khz
Video codec: H.264
Progressive scan (no interlacing)
High Profile
2 consecutive B frames
Closed GOP. GOP of half the frame rate.
CABAC
Variable bitrate. No bitrate limit required, though we offer recommended bit rates below for reference
Chroma subsampling: 4:2:0
